Merge multiple particle fluids
haggi
I want to do some lowres simulations and then merge the exported sims to one big simulation.
Now I have 4 sims on disk and want to merge them, but unfortuatly I didnt rename the particle fluid object so that in a merge node only one particle fluid objects is used, the last one in the merge node.
Do I have the possibility to merge all the particle fluid objects in my sim even if they have the same name?
