Nerox Posted June 19, 2009 Share Posted June 19, 2009 Maybe I'm just stupid but I just can't find the Point Cloud Write vex node. This is a Vop right? I would like to write a pointcloud to disk, so I'm able to use it in a Vop due to closesest points/ neighbours stuff. But it seems the pcopen needs a pointcloud file, through the forum/help I figured I need a Point Cloud Write node. But for what ever reason I'm not able to find it. Quote Link to comment Share on other sites More sharing options...
SpencerL Posted June 19, 2009 Share Posted June 19, 2009 Maybe I'm just stupid but I just can't find the Point Cloud Write vex node. This is a Vop right?I would like to write a pointcloud to disk, so I'm able to use it in a Vop due to closesest points/ neighbours stuff. But it seems the pcopen needs a pointcloud file, through the forum/help I figured I need a Point Cloud Write node. But for what ever reason I'm not able to find it. You write your points out in SOPs as either a .pc or .bgeo file and then the PC Open reads that file in. If you are doing the point cloud in anything but a shader context you can also use op:/obj/geo1/myNode which will read in the points without having to write them out to disk. If its a shader, then you do have to write your pts out to disk. Quote Link to comment Share on other sites More sharing options...
Nerox Posted June 19, 2009 Author Share Posted June 19, 2009 You write your points out in SOPs as either a .pc or .bgeo file and then the PC Open reads that file in. If you are doing the point cloud in anything but a shader context you can also use op:/obj/geo1/myNode which will read in the points without having to write them out to disk. If its a shader, then you do have to write your pts out to disk. I got it! I think I've tried al of these thing but I gues I missed this option ;-). But apart from that, why is there a Vop described in the help, that it isn't there? Wile there are others (according to the point cloud stuff), that aren't mentioned at all? Any way, I'll give it a shot. Thanks SpencerL! Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted June 19, 2009 Share Posted June 19, 2009 But apart from that, why is there a Vop described in the help, that it isn't there? Wile there are others (according to the point cloud stuff), that aren't mentioned at all? There is a Point Cloud Write VOP, but it is only available in the shading contexts, not SOPs. This is a wrapper for the pcwrite() VEX function. It lets you write point clouds from inside a shader, and is used heavily by the pyro shader, for example. Quote Link to comment Share on other sites More sharing options...
