Akira Posted June 22, 2009 Share Posted June 22, 2009 Hi all, I am very new to houdini. I downloaded and installed the latest build of houdini apprentice(295 build). But when i launch the application and start the help from the menu it hangs and when i try to quit the application it stop responding and i have to end the process from task manager. Later i had my env variable set to HOUDINI_DISABLE_CONSOLE = 1 then i was able to start and quit the application without any problem. But when i open a scene and work on it and later open another scene file it hangs, also after the env variable is set the help opens up but nothing is shown in it and also the start here link in help does not open anything. Please help me to get Houdini work properly with the help file. Thanx in advance. Note: I am using Windows XP, Nod32 antivirus, Houdini 10.0.295 build, core 2 2.13 ghz, 1gb ram. nvidia 8600 GTS latest drivers. Quote Link to comment Share on other sites More sharing options...
aracid Posted June 22, 2009 Share Posted June 22, 2009 Hey man I hate it when the program becomes a hassle to open try also submitting the bug here http://www.sidefx.com/index.php?option=com...&Itemid=239 they will probably point you in the right direction. cheers Quote Link to comment Share on other sites More sharing options...
Akira Posted June 22, 2009 Author Share Posted June 22, 2009 that was a very quick reply.. Ok i will submit a bug there. i also posted on there forum but didnt find any good answer to it. Quote Link to comment Share on other sites More sharing options...
