Save texture uv
AndrewVK
For some reason I can't open your file, but I can tell you this. Save to UV Texture in Apprentice suffers from limitations making it hard to use. It has the 640x480 limit so if you are trying to save at 512x512 or larger, it won't work, in fact I think it doesn't do anything, no errors, no nothing. The largest square size you can output is proabably 480x480. Also, the UV texture image gets watermarked. Try saving to something smaller and see if it works.
To work around it, you can try maximizing a UV viewport and taking a snapshot.
I think I posted about this on the SESI forums, I know I mentioned it here before, but I don't thinks it's been fixed, and honestlly I don't know if there's a way SESI can fix it without making some major changes to the software.
