AndrewVK Posted May 17, 2003 Share Posted May 17, 2003 Can anybody explain why "Save Texture UV to Image..." doesnt work in my case??? Quote Link to comment Share on other sites More sharing options...
AndrewVK Posted May 17, 2003 Author Share Posted May 17, 2003 oopss... why.zipFetching info... Quote Link to comment Share on other sites More sharing options...
Mcronin Posted May 17, 2003 Share Posted May 17, 2003 For some reason I can't open your file, but I can tell you this. Save to UV Texture in Apprentice suffers from limitations making it hard to use. It has the 640x480 limit so if you are trying to save at 512x512 or larger, it won't work, in fact I think it doesn't do anything, no errors, no nothing. The largest square size you can output is proabably 480x480. Also, the UV texture image gets watermarked. Try saving to something smaller and see if it works. To work around it, you can try maximizing a UV viewport and taking a snapshot. I think I posted about this on the SESI forums, I know I mentioned it here before, but I don't thinks it's been fixed, and honestlly I don't know if there's a way SESI can fix it without making some major changes to the software. Quote Link to comment Share on other sites More sharing options...
