pyro cache doesn't loading
sandzuro
I have an apprentice version on mac os. Pyro fx renders cache to files(as bgeo's sequence, as i read gz don't work on mac) and is set to load it from file . After reloading Houdini it just don't load this cache at all. All paths are correct, files are there, but no luck.
  • 3 weeks later...
Hi there,
Not sure which build you're using but try to download the latest which uses the Houdini browser by default and that allows you to select the pyro cache (.gz files) properly.
Please search through the SESI forum for posts related to this.
Cheers!
steven
