SHUTTER GLASS BY PROJECTING CURVES
Hello Im trying just for fun and practice shutter peace of glass by projecting curves onto nurbs surface, but. I have little problem. I create pattern by lines project on nurbs grid but now I dont know how I could separate peaces. Trim not work of course, Is there any way how to do that? I need only separate peaces, then convert poly, extrude, connect partition and destroy all in dops :whistling: there is picture and sample scene. Thanks a lot guys and nice weekend.
help_glass_01.hip
  • 2 weeks later...
what you can do, (havent had time to look at your scene)
convert your curves into curves, extrude your glas to give it some thickness
For each of your lines (not circles):
1) Extrude once -> to get a surface
2) Extrude once again to get some kind of "box"-thingy, this should be bigger than your piece of glas, you can then use to use the cookie-sop to do a boolean with the glas
For each of your circles:
1) extrude once
2) use divide-sop with the remove-shared-edges so you get the caps
3) merge results of step 1 & 2 and do a fuse-sop
4) use for with cookie sop for boolean magic
you have to do some huge itteration thing going there to get the individual pieces which should work with a foreach sop or some kind of feedback -loop (old-style with files & such).
cheers Seb
Edited by Infernalspawn
