vop_computeTangents()
sanostol
i just stumbled on the vop_computeTangents function. Why is it not documented? or am I blind again?
what other precious functions are lurking around here? :blink:
Martin
Hey Martin, check out $HFS/houdini/vex/include/voplib.h
Thats where vop_computeTangents and all the other functions used in VOPS are found.
-Alan
i used this function in inline code node and it worked. then later I wanted to create a vop node otl and used it there. after finishing (everything worked fine) i deleted the initial inline network and bam the vopnode thows an error and calls the vop computeTangent an undefined instruction turning yellow.
do I have to add something to my vop code? do i have to link the voplib.h?
Martin
Martin
You can include voplib.h on the inline VOP if you want. Or, if you created a vex builder type asset you can include the files in the "outer code" section of the code tab in the type properties window. #include <voplib.h>
The Old School blog has a good series of tutorials on making vex builder type hda's if you haven't checked it out yet. Old School Blog
@Alanw
thanks again
Hi SWANN,
I use it to create tangents for a Normalmapping. See the attached otl
You need a normalmap and a uvprojection to work that's it.
tanU and tanV have to be declared before You can use the function. The result is stored inside them.
there is another interesting function: vop_anisotropic
is there any help about it?
MM_ZBrush.otl
Edited by sanostol
