Obj import node fails to work in Domino tutorial?
maphysart
I am studying the Gnomon rigid body dynamics DVD and have a problem.
the high res model did not move according to the simplified model when using the object import node.
I find the tip in the forum. But the methods inside still failed to work.
Please give me some hints. Thanks a lot.
In the attachment is hip file.
test2.hip
The only difference between the hip file and mine is that I copied along the path.
yes, one minor difference is pretty much all it takes to screw up everything
but seriously
there is more differences than you may think
you are copying dominos to curve on SOP level
then you are using RBD fracture object to import the groups as rbd objects
this way all domino pieces will have the same center and that's the reason for DopImport importing all the objects on the same spot
so either you copy hi res dominos on the same curve and use dopimport on result groups
or
take a closer look at the file you think is almost the same as yours
notice that the dominos are imported to DOPs as RBD point object which is the way to go
look at attachment to see your file modified
and one more thing
never use "Use Deforming Geometry" checkbox on your RBD objects unless you really need to
so only if the geometry is deforming over time(and you need it to be considered for simulation)
or
if you really want your simulation to take hours instead of minutes
test2_fix.hip
Thank you for your help. I try both methods you suggest. Both of them works. Great.
And your modified version is more concise and directly. I prefer to use rbd point in the future.
Yes, as what you said, the difference is not obvious but big enough.
Besides, I should turn off the deforming the geometry option. it becomes really faster.
thanks again.
