phong Posted July 13, 2009 Share Posted July 13, 2009 Hi! I tried to install HOT on my linux64 machine with H10. I built HOT from the latest source just like in the guide. After compiling with compile_linux.sh I opened the example sop_simple.hip and right after opening the file a lot of error messages appear that parameters can not be found, bad node types are in the file, etc.. So I guess I must do something wrong. Do I need to do anything else after building and compiling to get HOT running? Quote Link to comment Share on other sites More sharing options...
eloop Posted July 14, 2009 Share Posted July 14, 2009 Hi Phong, Can you post the output of the compile_linux.sh command ? -Drew Hi!I tried to install HOT on my linux64 machine with H10. I built HOT from the latest source just like in the guide. After compiling with compile_linux.sh I opened the example sop_simple.hip and right after opening the file a lot of error messages appear that parameters can not be found, bad node types are in the file, etc.. So I guess I must do something wrong. Do I need to do anything else after building and compiling to get HOT running? Quote Link to comment Share on other sites More sharing options...
phong Posted July 14, 2009 Author Share Posted July 14, 2009 Hi Phong,Can you post the output of the compile_linux.sh command ? -Drew Sure! Linking with 'libblitz'Linking with 'libfftw3f' g++ -DUT_DSO_TAGINFO='"3262197cbf015d1525a0029a431a9df5255bcdbdca308aac73a8c3063d69ee812b972985db32267a5946addc329f31761ea2f501fbc2e85049032de266fd81be4bae5c8aff924994a3268d0847f848e6ab4e86a48ee49f6be1b237"' -DVERSION=\"10.0.249.3\" -DDLLEXPORT= -D_GNU_SOURCE -DLINUX -DAMD64 -m64 -fPIC -DSIZEOF_VOID_P=8 -DSESI_LITTLE_ENDIAN -DENABLE_THREADS -DUSE_PTHREADS -D_REENTRANT -D_FILE_OFFSET_BITS=64 -c -I./3rdparty/include -I./3rdparty/linux/include -DGCC4 -DGCC3 -Wno-deprecated -I/opt/hfs10.0.249.3/toolkit/include -I/opt/hfs10.0.249.3/toolkit/include/htools -Wall -W -Wno-parentheses -Wno-sign-compare -Wno-reorder -Wno-uninitialized -Wunused -Wno-unused-parameter -O2 -DMAKING_DSO -o SOP_Ocean.o SOP_Ocean.C In file included from ./3rdparty/linux/include/blitz/array-impl.h:42, from ./3rdparty/linux/include/blitz/array.h:32, from Ocean.h:75, from SOP_Ocean.h:32, from SOP_Ocean.C:33: ./3rdparty/linux/include/blitz/memblock.h:128: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/memblock.h:133: warning: type qualifiers ignored on function return type In file included from ./3rdparty/linux/include/blitz/array-impl.h:44, from ./3rdparty/linux/include/blitz/array.h:32, from Ocean.h:75, from SOP_Ocean.h:32, from SOP_Ocean.C:33: ./3rdparty/linux/include/blitz/tinyvec.h:229: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/tinyvec.h:232: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/tinyvec.h:235: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/tinyvec.h:238: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/tinyvec.h:411: warning: type qualifiers ignored on function return type In file included from ./3rdparty/linux/include/blitz/tinyvec.h:430, from ./3rdparty/linux/include/blitz/array-impl.h:44, from ./3rdparty/linux/include/blitz/array.h:32, from Ocean.h:75, from SOP_Ocean.h:32, from SOP_Ocean.C:33: ./3rdparty/linux/include/blitz/vector.h:194: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/vector.h:197: warning: type qualifiers ignored on function return type In file included from ./3rdparty/linux/include/blitz/array.h:32, from Ocean.h:75, from SOP_Ocean.h:32, from SOP_Ocean.C:33: ./3rdparty/linux/include/blitz/array-impl.h:875: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/array-impl.h:878: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/array-impl.h:884: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/array-impl.h:887: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/array-impl.h:908: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/array-impl.h:913: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/array-impl.h:2321: warning: type qualifiers ignored on function return type In file included from ./3rdparty/linux/include/blitz/array-impl.h:2508, from ./3rdparty/linux/include/blitz/array.h:32, from Ocean.h:75, from SOP_Ocean.h:32, from SOP_Ocean.C:33: ./3rdparty/linux/include/blitz/array/iter.h:103: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/array/iter.h:158: warning: type qualifiers ignored on function return type In file included from ./3rdparty/linux/include/blitz/array-impl.h:2509, from ./3rdparty/linux/include/blitz/array.h:32, from Ocean.h:75, from SOP_Ocean.h:32, from SOP_Ocean.C:33: ./3rdparty/linux/include/blitz/array/fastiter.h:156: warning: type qualifiers ignored on function return type In file included from ./3rdparty/linux/include/blitz/array/stencilops.h:39, from ./3rdparty/linux/include/blitz/array/stencils.h:31, from ./3rdparty/linux/include/blitz/array-impl.h:2525, from ./3rdparty/linux/include/blitz/array.h:32, from Ocean.h:75, from SOP_Ocean.h:32, from SOP_Ocean.C:33: ./3rdparty/linux/include/blitz/tinymat.h:59: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/tinymat.h:83: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/tinymat.h:86: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/tinymat.h:89: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/tinymat.h:92: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/tinymat.h:131: warning: type qualifiers ignored on function return type g++ -shared SOP_Ocean.o -L/usr/X11R6/lib -I./3rdparty/include -I./3rdparty/linux/include -L./3rdparty/linux/lib -lblitz -lfftw3f -lGLU -lGL -lX11 -lXext -lXi -ldl -o /home/stafford/houdini10.0/dso/SOP_Ocean.so /usr/lib64/gcc/x86_64-suse-linux/4.3/../../../../x86_64-suse-linux/bin/ld: cannot find -lblitz collect2: ld returned 1 exit status g++ -DUT_DSO_TAGINFO='"3262197cbf015d1525a0029a431a9df5255bcdbdca308aac73a8c3063d69ee812b972985db32267a5946addc329f31761ea2f501fbc2e85049032de265fe81be4bae5c8aff924994a3268d0847f848e6ab4e86a48ee49f6be1b237"' -DVERSION=\"10.0.249.3\" -DDLLEXPORT= -D_GNU_SOURCE -DLINUX -DAMD64 -m64 -fPIC -DSIZEOF_VOID_P=8 -DSESI_LITTLE_ENDIAN -DENABLE_THREADS -DUSE_PTHREADS -D_REENTRANT -D_FILE_OFFSET_BITS=64 -c -I./3rdparty/include -I./3rdparty/linux/include -DGCC4 -DGCC3 -Wno-deprecated -I/opt/hfs10.0.249.3/toolkit/include -I/opt/hfs10.0.249.3/toolkit/include/htools -Wall -W -Wno-parentheses -Wno-sign-compare -Wno-reorder -Wno-uninitialized -Wunused -Wno-unused-parameter -O2 -DMAKING_DSO -o VEX_Ocean.o VEX_Ocean.C In file included from ./3rdparty/linux/include/blitz/array-impl.h:42, from ./3rdparty/linux/include/blitz/array.h:32, from Ocean.h:75, from VEX_Ocean.C:32: ./3rdparty/linux/include/blitz/memblock.h:128: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/memblock.h:133: warning: type qualifiers ignored on function return type In file included from ./3rdparty/linux/include/blitz/array-impl.h:44, from ./3rdparty/linux/include/blitz/array.h:32, from Ocean.h:75, from VEX_Ocean.C:32: ./3rdparty/linux/include/blitz/tinyvec.h:229: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/tinyvec.h:232: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/tinyvec.h:235: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/tinyvec.h:238: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/tinyvec.h:411: warning: type qualifiers ignored on function return type In file included from ./3rdparty/linux/include/blitz/tinyvec.h:430, from ./3rdparty/linux/include/blitz/array-impl.h:44, from ./3rdparty/linux/include/blitz/array.h:32, from Ocean.h:75, from VEX_Ocean.C:32: ./3rdparty/linux/include/blitz/vector.h:194: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/vector.h:197: warning: type qualifiers ignored on function return type In file included from ./3rdparty/linux/include/blitz/array.h:32, from Ocean.h:75, from VEX_Ocean.C:32: ./3rdparty/linux/include/blitz/array-impl.h:875: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/array-impl.h:878: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/array-impl.h:884: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/array-impl.h:887: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/array-impl.h:908: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/array-impl.h:913: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/array-impl.h:2321: warning: type qualifiers ignored on function return type In file included from ./3rdparty/linux/include/blitz/array-impl.h:2508, from ./3rdparty/linux/include/blitz/array.h:32, from Ocean.h:75, from VEX_Ocean.C:32: ./3rdparty/linux/include/blitz/array/iter.h:103: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/array/iter.h:158: warning: type qualifiers ignored on function return type In file included from ./3rdparty/linux/include/blitz/array-impl.h:2509, from ./3rdparty/linux/include/blitz/array.h:32, from Ocean.h:75, from VEX_Ocean.C:32: ./3rdparty/linux/include/blitz/array/fastiter.h:156: warning: type qualifiers ignored on function return type In file included from ./3rdparty/linux/include/blitz/array/stencilops.h:39, from ./3rdparty/linux/include/blitz/array/stencils.h:31, from ./3rdparty/linux/include/blitz/array-impl.h:2525, from ./3rdparty/linux/include/blitz/array.h:32, from Ocean.h:75, from VEX_Ocean.C:32: ./3rdparty/linux/include/blitz/tinymat.h:59: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/tinymat.h:83: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/tinymat.h:86: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/tinymat.h:89: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/tinymat.h:92: warning: type qualifiers ignored on function return type ./3rdparty/linux/include/blitz/tinymat.h:131: warning: type qualifiers ignored on function return type g++ -shared VEX_Ocean.o -L/usr/X11R6/lib -I./3rdparty/include -I./3rdparty/linux/include -L./3rdparty/linux/lib -lblitz -lfftw3f -lGLU -lGL -lX11 -lXext -lXi -ldl -o /home/stafford/houdini10.0/dso/VEX_Ocean.so /usr/lib64/gcc/x86_64-suse-linux/4.3/../../../../x86_64-suse-linux/bin/ld: cannot find -lblitz collect2: ld returned 1 exit status g++ -DUT_DSO_TAGINFO='"3262197cbf015d1525a0029a431a9df5255bcdbdca308aac73a8c3063d69ee812b972985db32267a5946addc329f31761ea2f501fbc2e85049032de265fd81be4bae5c8aff924994a3268d0847f848e6ab4e86a48ee49f6be1b237"' -DVERSION=\"10.0.249.3\" -DDLLEXPORT= -D_GNU_SOURCE -DLINUX -DAMD64 -m64 -fPIC -DSIZEOF_VOID_P=8 -DSESI_LITTLE_ENDIAN -DENABLE_THREADS -DUSE_PTHREADS -D_REENTRANT -D_FILE_OFFSET_BITS=64 -c -I./3rdparty/include -I./3rdparty/linux/include -DGCC4 -DGCC3 -Wno-deprecated -I/opt/hfs10.0.249.3/toolkit/include -I/opt/hfs10.0.249.3/toolkit/include/htools -Wall -W -Wno-parentheses -Wno-sign-compare -Wno-reorder -Wno-uninitialized -Wunused -Wno-unused-parameter -O2 -DMAKING_DSO -o SOP_Cleave.o SOP_Cleave.C g++ -shared SOP_Cleave.o -L/usr/X11R6/lib -I./3rdparty/include -I./3rdparty/linux/include -L./3rdparty/linux/lib -lblitz -lfftw3f -lGLU -lGL -lX11 -lXext -lXi -ldl -o /home/stafford/houdini10.0/dso/SOP_Cleave.so /usr/lib64/gcc/x86_64-suse-linux/4.3/../../../../x86_64-suse-linux/bin/ld: cannot find -lblitz collect2: ld returned 1 exit status Done compiling and installing the DSO's to /home/stafford/houdini10.0/dso. Done installing the icon files to /home/stafford/houdini10.0/config/Icons. Done installing and editing /home/stafford/houdini10.0/vex/VEXdso. All done. You can now try loading ../examples_and_otl/sop_simple.hip Quote Link to comment Share on other sites More sharing options...
phong Posted July 14, 2009 Author Share Posted July 14, 2009 Enclosed is a snapshot of the error messages in Houdini when I open the SOP_simple.hip file. Quote Link to comment Share on other sites More sharing options...
eloop Posted July 15, 2009 Share Posted July 15, 2009 Looks like the 3rd party libraries are'nt being found. Just checking, did you build them first ? > cd 3rdparty > ./build_linux.sh Then you should see this in the linux/lib directory ... > ls linux/lib/ libblitz.a libfftw3f.a libfftw3f_threads.a pkgconfig libblitz.la libfftw3f.la libfftw3f_threads.la -Drew Quote Link to comment Share on other sites More sharing options...
phong Posted July 15, 2009 Author Share Posted July 15, 2009 Looks like the 3rd party libraries are'nt being found. Just checking, did you build them first ?> cd 3rdparty > ./build_linux.sh Then you should see this in the linux/lib directory ... > ls linux/lib/ libblitz.a libfftw3f.a libfftw3f_threads.a pkgconfig libblitz.la libfftw3f.la libfftw3f_threads.la -Drew Yes, I built them first, but for some reason all files except the libblitz ones are missing in my linux/lib directory. Do you know why this could happen? Quote Link to comment Share on other sites More sharing options...
eloop Posted July 15, 2009 Share Posted July 15, 2009 Yes, I built them first, but for some reason all files except the libblitz ones are missing in my linux/lib directory. Do you know why this could happen? I haven't seen this, can you post the output of build_linux.sh. Something must be going wrong with the building of blitz. -Drew Quote Link to comment Share on other sites More sharing options...
phong Posted July 15, 2009 Author Share Posted July 15, 2009 The entire output is A LOT longer.. checking whether stripping libraries is possible... yes checking if libtool supports shared libraries... yes checking whether to build shared libraries... no checking whether to build static libraries... yes configure: creating libtool appending configuration tag "CXX" to libtool checking for ld used by c++... /usr/x86_64-suse-linux/bin/ld -m elf_x86_64 checking if the linker (/usr/x86_64-suse-linux/bin/ld -m elf_x86_64) is GNU ld... yes checking whether the c++ linker (/usr/x86_64-suse-linux/bin/ld -m elf_x86_64) supports shared libraries... yes checking for c++ option to produce PIC... -fPIC checking if c++ PIC flag -fPIC works... yes checking if c++ supports -c -o file.o... yes checking whether the c++ linker (/usr/x86_64-suse-linux/bin/ld -m elf_x86_64) supports shared libraries... yes checking dynamic linker characteristics... GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking whether stripping libraries is possible... yes appending configuration tag "F77" to libtool checking for sin... yes configure: Checking to see if there is a usable BLAS library kicking around... (If so, Blitz++ will use BLAS library to run benchmarks against if you build the benchmarks. Blitz++ itself does NOT use BLAS). checking for daxpy_ in -lblas... no checking for daxpy in -lblas... no checking for DAXPY in -lblas... no checking for daxpy__ in -lblas... no checking whether to enable c++ optimization flags... yes checking whether to enable c++ debug flags... no configure: C++ compiler (c++ -O3 -funroll-loops -fstrict-aliasing -fomit-frame-pointer -ffast-math ) characteristics configure: Checking major C++ language features checking whether the compiler implements namespaces... yes checking whether the compiler supports exceptions... yes checking whether the compiler supports Run-Time Type Identification... yes checking whether the compiler supports member constants... yes checking whether the compiler accepts the old for scoping rules... no configure: Now for some of the new keywords checking whether the compiler supports the explicit keyword... yes checking whether the compiler supports the mutable keyword... yes checking whether the compiler recognizes typename... yes checking whether the compiler supports the Numerical C Extensions Group restrict keyword... no checking whether the compiler recognizes the '__restrict__' keyword... yes checking whether the compiler recognizes bool as a built-in type... yes configure: Does your compiler understand the newfangled casting syntax? checking whether the compiler supports const_cast<>... yes checking whether the compiler supports static_cast<>... yes checking whether the compiler supports reinterpret_cast<>... yes checking whether the compiler supports dynamic_cast<>... yes configure: Okay, now the important stuff -- templates checking whether the compiler supports basic templates... yes checking whether the compiler supports partial specialization... yes checking whether the compiler supports partial ordering... yes checking whether the compiler supports default template parameters... yes checking whether the compiler supports member templates... yes checking whether the compiler supports member templates outside the class declaration... yes checking whether the compiler recognizes the full specialization syntax... yes checking whether the compiler supports function templates with non-type parameters... yes checking whether the compiler supports template-qualified base class specifiers... yes checking whether the compiler supports template-qualified return types... yes checking whether the compiler supports explicit template function qualification... yes checking whether the compiler supports templates as template arguments... yes checking whether the compiler supports use of the template keyword as a qualifier... yes checking whether the compiler supports function matching with argument types which are template scope-qualified... yes checking whether the compiler will support the vector type promotion mechanism... yes checking whether the compiler supports numeric traits promotions... yes checking whether the compiler handle computations inside an enum... yes checking whether the compiler handles (int) casts in enum computations... yes configure: Which library features does your compiler provide? checking whether the compiler has complex<T>... yes checking whether the compiler has standard complex<T> functions... yes checking whether the compiler has numeric_limits<T>... yes checking whether the compiler has <climits> header... yes checking whether the compiler has valarray<T>... yes checking whether the compiler has complex math functions... yes checking whether the compiler has more complex math functions... no checking whether the compiler supports IEEE math library... yes checking whether the compiler supports System V math library... no checking whether the compiler has C math functions in namespace std... yes checking whether complex math functions are in namespace std... yes checking whether the compiler has isnan function in namespace std... yes checking whether the compiler supports ISO C++ standard library... yes checking whether the compiler supports Standard Template Library... yes checking whether the compiler has getrusage() function... yes configure: CXX = c++ CXXFLAGS = -O3 -funroll-loops -fstrict-aliasing -fomit-frame-pointer -ffast-math CXX_OPTIMIZE_FLAGS = -O3 -funroll-loops -fstrict-aliasing -fomit-frame-pointer -ffast-math CXX_DEBUG_FLAGS = -g -DBZ_DEBUG CXXFFLAGS = F77 = FFLAGS = F77_OPTIMIZE_FLAGS = FLIBS = FC = FCFLAGS = FC_OPTIMIZE_FLAGS = FCLIBS = BLASLIB = checking our pkgconfig libname... blitz checking our pkgconfig version... 0.9 checking our pkgconfig_libdir... ${libdir}/pkgconfig expanded our pkgconfig_libdir... //home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/lib/pkgconfig checking our pkgconfig_libfile... blitz.pc checking our pkgconfig description... blitz Library checking our pkgconfig requires... checking our pkgconfig ext libs... -lblitz checking our pkgconfig cppflags... noninstalled pkgconfig -L //home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/src/.libs noninstalled pkgconfig -I //home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/. configure: creating ./config.status config.status: creating Makefile config.status: creating bin/Makefile config.status: creating blitz/Makefile config.status: creating blitz/array/Makefile config.status: creating blitz/generate/Makefile config.status: creating blitz/meta/Makefile config.status: creating random/Makefile config.status: creating lib/Makefile config.status: creating testsuite/Makefile config.status: creating examples/Makefile config.status: creating doc/Makefile config.status: creating doc/examples/Makefile config.status: creating doc/stencils/Makefile config.status: creating doc/doxygen/Makefile config.status: creating doc/doxygen/Doxyfile config.status: creating benchmarks/Makefile config.status: creating benchmarks/plot_benchmarks.m config.status: creating blitz/config.h config.status: executing depfiles commands config.status: executing blitz/gnu/bzconfig.h commands config.status: creating blitz/gnu/bzconfig.h - prefix BZ for blitz/config.h defines config.status: executing blitz.pc commands config.status: creating blitz.pc.in config.status: creating blitz.pc config.status: creating blitz-uninstalled.pc configure: The configure script has generated makefiles for your platform. You have several options now: make lib Check the compiler and create libblitz.a make check-testsuite Build and check the testsuite make check-examples Build and check the examples make check-benchmarks Build and check the benchmarks (takes a long time) make install Install Blitz++ Making clean in doc make[1]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/doc' Making clean in doxygen make[2]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/doc/doxygen' rm -rf .libs _libs rm -f *.lo make[2]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/doc/doxygen' Making clean in stencils make[2]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/doc/stencils' rm -rf .libs _libs rm -rf *.ii *.ti cxx_repository Template.dir ii_files ti_files dump-stencil *.texi rm -f *.lo make[2]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/doc/stencils' Making clean in examples make[2]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/doc/examples' rm -rf .libs _libs rm -rf *.ii *.ti cxx_repository Template.dir ii_files ti_files simple storage outer strideslice slicing debug output io dump xor cast range fixed *.texi *.out core.[0-9]* rm -f *.o rm -f *.lo make[2]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/doc/examples' Making clean in . make[2]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/doc' test -z "blitz.tmp" || rm -f blitz.tmp rm -rf .libs _libs rm -rf blitz*.html rm -rf blitz.aux blitz.cp blitz.cps blitz.fn blitz.fns blitz.ky blitz.kys \ blitz.log blitz.pg blitz.pgs blitz.tmp blitz.toc blitz.tp \ blitz.tps blitz.vr blitz.vrs blitz.dvi blitz.pdf blitz.ps \ blitz.html rm -f *.lo rm -f vti.tmp make[2]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/doc' make[1]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/doc' Making clean in benchmarks make[1]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/benchmarks' rm -rf .libs _libs rm -rf *.ii *.ti *.int.c *.s work.pc* cxx_repository Template.dir ii_files ti_files core.[0-9]* \ loop1 loop2 loop3 loop5 loop6 loop8 loop9 loop10 loop11 loop12 loop13 loop14 loop15 loop16 loop17 loop18 loop19 loop21 loop22 loop23 loop24 loop25 loop36 daxpy haney qcd stencil tinydaxpy acoustic acou3d hao-he ctime1 ctime2 ctime3 ctime4 ctime5 ctime1v ctime2v ctime3v ctime4v ctime5v rm -f *.o rm -f *.lo make[1]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/benchmarks' Making clean in examples make[1]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/examples' rm -rf .libs _libs rm -rf *.ii *.ti cxx_repository Template.dir ii_files ti_files array cartesian cast cfd complex-test convolve curldiv deriv diff erf fixed indirect io iter matmult nested numinquire outer pauli pick polymorph prettyprint qcd rand2 random rangexpr reduce simple slicing stencil2 stencil3 stencil stencilet storage tiny transform useret where whitt rm -f *.o rm -f *.lo make[1]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/examples' Making clean in testsuite make[1]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/testsuite' rm -rf .libs _libs rm -rf *.ii *.ti cxx_repository Template.dir ii_files ti_files Adnene-Ben-Abdallah-1 Adnene-Ben-Abdallah-2 arrayresize chris-jeffery-1 chris-jeffery-2 chris-jeffery-3 complex-test constarray contiguous copy ctors derrick-bass-1 derrick-bass-3 exprctor extract free gary-huber-1 initialize interlace iter Josef-Wagenhuber loop1 matthias-troyer-1 matthias-troyer-2 mattias-lindstroem-1 minmax minsumpow module newet Olaf-Ronneberger-1 peter-bienstman-1 peter-bienstman-2 peter-bienstman-3 peter-bienstman-4 peter-bienstman-5 peter-nordlund-1 peter-nordlund-2 peter-nordlund-3 promote qcd reduce reindex reverse shapecheck shape storage stub theodore-papadopoulo-1 tinymat tinyvec transpose troyer-genilloud Ulisses-Mello-1 wei-ku-1 where rm -f *.o rm -f *.lo make[1]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/testsuite' Making clean in lib make[1]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/lib' test -z "libblitz.la" || rm -f libblitz.la rm -f "./so_locations" rm -rf .libs _libs rm -rf *.ii *.ti cxx_repository Template.dir ii_files ti_files rm -f *.o rm -f *.lo make[1]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/lib' Making clean in random make[1]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/random' rm -rf .libs _libs rm -f *.lo make[1]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/random' Making clean in blitz make[1]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz' Making clean in array make[2]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/array' rm -rf .libs _libs rm -f *.lo make[2]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/array' Making clean in meta make[2]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/meta' rm -rf .libs _libs rm -f *.lo make[2]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/meta' Making clean in generate make[2]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/generate' rm -rf .libs _libs rm -rf cxx_repository ti_files ii_files genarrbops genmathfunc genvecbops genarruops genmatuops genvecuops genmatbops genpromote genvecwhere genvecbfn rm -f *.o rm -f *.lo make[2]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/generate' Making clean in . make[2]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz' rm -rf .libs _libs rm -rf config.h rm -f *.lo make[2]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz' make[1]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz' Making clean in bin make[1]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/bin' rm -rf .libs _libs rm -f *.lo make[1]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/bin' Making clean in . make[1]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9' rm -rf .libs _libs rm -rf *.ii *.ti cxx_repository Template.dir ii_files ti_files rm -f *.lo make[1]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9' if /bin/sh ../libtool --mode=compile --tag=CXX c++ -DHAVE_CONFIG_H -I.. -I.. -O3 -funroll-loops -fstrict-aliasing -fomit-frame-pointer -ffast-math -MT globals.lo -MD -MP -MF ".deps/globals.Tpo" -c -o globals.lo `test -f '../src/globals.cpp' || echo './'`../src/globals.cpp; \ then mv -f ".deps/globals.Tpo" ".deps/globals.Plo"; else rm -f ".deps/globals.Tpo"; exit 1; fi c++ -DHAVE_CONFIG_H -I.. -I.. -O3 -funroll-loops -fstrict-aliasing -fomit-frame-pointer -ffast-math -MT globals.lo -MD -MP -MF .deps/globals.Tpo -c ../src/globals.cpp -o globals.o In file included from ../blitz/applics.h:400, from ../blitz/vecexpr.h:32, from ../blitz/vecpick.cc:16, from ../blitz/vecpick.h:293, from ../blitz/vector.h:449, from ../blitz/tinyvec.h:430, from ../blitz/indexexpr.h:30, from ../src/globals.cpp:11: ../blitz/mathfunc.h: In static member function 'static long int blitz::_bz_abs<long int>::apply(long int)': ../blitz/mathfunc.h:45: error: 'labs' is not a member of 'std' In file included from ../blitz/array/funcs.h:29, from ../blitz/array/newet.h:29, from ../blitz/array/et.h:27, from ../blitz/array-impl.h:2515, from ../blitz/array.h:32, from ../src/globals.cpp:13: ../blitz/funcs.h: In static member function 'static int blitz::Fn_abs<int>::apply(int)': ../blitz/funcs.h:509: error: call of overloaded 'abs(int&)' is ambiguous /usr/include/c++/4.3/cmath:99: note: candidates are: double std::abs(double) /usr/include/c++/4.3/cmath:103: note: float std::abs(float) /usr/include/c++/4.3/cmath:107: note: long double std::abs(long double) ../blitz/funcs.h: In static member function 'static long int blitz::Fn_abs<long int>::apply(long int)': ../blitz/funcs.h:530: error: 'labs' is not a member of 'std' make: *** [globals.lo] Error 1 Making install in generate make[1]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/generate' make generate-headers make[2]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/generate' make[2]: Nothing to be done for `generate-headers'. make[2]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/generate' make[2]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/generate' make[2]: Nothing to be done for `install-exec-am'. make[2]: Nothing to be done for `install-data-am'. make[2]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/generate' make[1]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/generate' Making install in meta make[1]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/meta' make[2]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/meta' make[2]: Nothing to be done for `install-exec-am'. test -z "//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/meta" || mkdir -p -- "//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/meta" /usr/bin/install -c -m 644 'dot.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/meta/dot.h' /usr/bin/install -c -m 644 'matassign.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/meta/matassign.h' /usr/bin/install -c -m 644 'matmat.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/meta/matmat.h' /usr/bin/install -c -m 644 'matvec.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/meta/matvec.h' /usr/bin/install -c -m 644 'metaprog.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/meta/metaprog.h' /usr/bin/install -c -m 644 'product.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/meta/product.h' /usr/bin/install -c -m 644 'sum.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/meta/sum.h' /usr/bin/install -c -m 644 'vecassign.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/meta/vecassign.h' make[2]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/meta' make[1]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/meta' Making install in array make[1]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/array' make[2]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/array' make[2]: Nothing to be done for `install-exec-am'. test -z "//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array" || mkdir -p -- "//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array" /usr/bin/install -c -m 644 'asexpr.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/asexpr.h' /usr/bin/install -c -m 644 'cartesian.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/cartesian.h' /usr/bin/install -c -m 644 'cgsolve.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/cgsolve.h' /usr/bin/install -c -m 644 'complex.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/complex.cc' /usr/bin/install -c -m 644 'convolve.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/convolve.cc' /usr/bin/install -c -m 644 'convolve.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/convolve.h' /usr/bin/install -c -m 644 'cycle.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/cycle.cc' /usr/bin/install -c -m 644 'domain.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/domain.h' /usr/bin/install -c -m 644 'et.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/et.h' /usr/bin/install -c -m 644 'eval.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/eval.cc' /usr/bin/install -c -m 644 'expr.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/expr.h' /usr/bin/install -c -m 644 'fastiter.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/fastiter.h' /usr/bin/install -c -m 644 'funcs.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/funcs.h' /usr/bin/install -c -m 644 'functorExpr.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/functorExpr.h' /usr/bin/install -c -m 644 'geometry.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/geometry.h' /usr/bin/install -c -m 644 'indirect.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/indirect.h' /usr/bin/install -c -m 644 'interlace.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/interlace.cc' /usr/bin/install -c -m 644 'io.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/io.cc' /usr/bin/install -c -m 644 'iter.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/iter.h' /usr/bin/install -c -m 644 'map.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/map.h' /usr/bin/install -c -m 644 'methods.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/methods.cc' /usr/bin/install -c -m 644 'misc.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/misc.cc' /usr/bin/install -c -m 644 'multi.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/multi.h' /usr/bin/install -c -m 644 'newet-macros.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/newet-macros.h' /usr/bin/install -c -m 644 'newet.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/newet.h' /usr/bin/install -c -m 644 'ops.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/ops.cc' /usr/bin/install -c -m 644 'ops.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/ops.h' /usr/bin/install -c -m 644 'reduce.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/reduce.cc' /usr/bin/install -c -m 644 'reduce.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/reduce.h' /usr/bin/install -c -m 644 'resize.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/resize.cc' /usr/bin/install -c -m 644 'shape.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/shape.h' /usr/bin/install -c -m 644 'slice.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/slice.h' /usr/bin/install -c -m 644 'slicing.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/slicing.cc' /usr/bin/install -c -m 644 'stencil-et.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/stencil-et.h' /usr/bin/install -c -m 644 'stencilops.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/stencilops.h' /usr/bin/install -c -m 644 'stencils.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/stencils.cc' /usr/bin/install -c -m 644 'stencils.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/stencils.h' /usr/bin/install -c -m 644 'storage.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/storage.h' /usr/bin/install -c -m 644 'where.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/where.h' /usr/bin/install -c -m 644 'zip.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/zip.h' /usr/bin/install -c -m 644 'bops.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/bops.cc' /usr/bin/install -c -m 644 'uops.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array/uops.cc' make[2]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/array' make[1]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/array' make[1]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz' make[2]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz' cd .. && /bin/sh ./config.status blitz/config.h config.status: creating blitz/config.h make[2]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz' make[2]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz' make[2]: Nothing to be done for `install-exec-am'. test -z "//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz" || mkdir -p -- "//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz" /usr/bin/install -c -m 644 'applics.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/applics.h' /usr/bin/install -c -m 644 'array-impl.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array-impl.h' /usr/bin/install -c -m 644 'array-old.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array-old.h' /usr/bin/install -c -m 644 'array.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/array.h' /usr/bin/install -c -m 644 'bench.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/bench.cc' /usr/bin/install -c -m 644 'bench.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/bench.h' /usr/bin/install -c -m 644 'benchext.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/benchext.cc' /usr/bin/install -c -m 644 'benchext.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/benchext.h' /usr/bin/install -c -m 644 'blitz.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/blitz.h' /usr/bin/install -c -m 644 'bzconfig.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/bzconfig.h' /usr/bin/install -c -m 644 'bzdebug.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/bzdebug.h' /usr/bin/install -c -m 644 'compiler.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/compiler.h' /usr/bin/install -c -m 644 'etbase.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/etbase.h' /usr/bin/install -c -m 644 'extremum.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/extremum.h' /usr/bin/install -c -m 644 'funcs.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/funcs.h' /usr/bin/install -c -m 644 'indexexpr.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/indexexpr.h' /usr/bin/install -c -m 644 'limits-hack.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/limits-hack.h' /usr/bin/install -c -m 644 'listinit.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/listinit.h' /usr/bin/install -c -m 644 'matdiag.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/matdiag.h' /usr/bin/install -c -m 644 'matexpr.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/matexpr.h' /usr/bin/install -c -m 644 'matgen.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/matgen.h' /usr/bin/install -c -m 644 'mathf2.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/mathf2.h' /usr/bin/install -c -m 644 'matltri.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/matltri.h' /usr/bin/install -c -m 644 'matref.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/matref.h' /usr/bin/install -c -m 644 'matrix.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/matrix.cc' /usr/bin/install -c -m 644 'matrix.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/matrix.h' /usr/bin/install -c -m 644 'matsymm.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/matsymm.h' /usr/bin/install -c -m 644 'mattoep.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/mattoep.h' /usr/bin/install -c -m 644 'matutri.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/matutri.h' /usr/bin/install -c -m 644 'memblock.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/memblock.cc' /usr/bin/install -c -m 644 'memblock.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/memblock.h' /usr/bin/install -c -m 644 'minmax.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/minmax.h' /usr/bin/install -c -m 644 'mstruct.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/mstruct.h' /usr/bin/install -c -m 644 'numinquire.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/numinquire.h' /usr/bin/install -c -m 644 'numtrait.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/numtrait.h' /usr/bin/install -c -m 644 'ops.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/ops.h' /usr/bin/install -c -m 644 'prettyprint.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/prettyprint.h' /usr/bin/install -c -m 644 'promote.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/promote.h' /usr/bin/install -c -m 644 'rand-dunif.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/rand-dunif.h' /usr/bin/install -c -m 644 'rand-mt.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/rand-mt.h' /usr/bin/install -c -m 644 'rand-normal.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/rand-normal.h' /usr/bin/install -c -m 644 'rand-tt800.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/rand-tt800.h' /usr/bin/install -c -m 644 'rand-uniform.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/rand-uniform.h' /usr/bin/install -c -m 644 'random.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/random.h' /usr/bin/install -c -m 644 'randref.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/randref.h' /usr/bin/install -c -m 644 'range.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/range.h' /usr/bin/install -c -m 644 'reduce.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/reduce.h' /usr/bin/install -c -m 644 'shapecheck.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/shapecheck.h' /usr/bin/install -c -m 644 'tau.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/tau.h' /usr/bin/install -c -m 644 'timer.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/timer.h' /usr/bin/install -c -m 644 'tiny.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/tiny.h' /usr/bin/install -c -m 644 'tinymat.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/tinymat.h' /usr/bin/install -c -m 644 'tinymatexpr.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/tinymatexpr.h' /usr/bin/install -c -m 644 'tinymatio.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/tinymatio.cc' /usr/bin/install -c -m 644 'tinyvec-et.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/tinyvec-et.h' /usr/bin/install -c -m 644 'tinyvec.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/tinyvec.cc' /usr/bin/install -c -m 644 'tinyvec.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/tinyvec.h' /usr/bin/install -c -m 644 'tinyvecio.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/tinyvecio.cc' /usr/bin/install -c -m 644 'tinyveciter.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/tinyveciter.h' /usr/bin/install -c -m 644 'traversal.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/traversal.cc' /usr/bin/install -c -m 644 'traversal.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/traversal.h' /usr/bin/install -c -m 644 'tuning.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/tuning.h' /usr/bin/install -c -m 644 'tvcross.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/tvcross.h' /usr/bin/install -c -m 644 'tvecglobs.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/tvecglobs.h' /usr/bin/install -c -m 644 'update.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/update.h' /usr/bin/install -c -m 644 'vecaccum.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecaccum.cc' /usr/bin/install -c -m 644 'vecall.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecall.cc' /usr/bin/install -c -m 644 'vecany.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecany.cc' /usr/bin/install -c -m 644 'vecbfn.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecbfn.cc' /usr/bin/install -c -m 644 'veccount.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/veccount.cc' /usr/bin/install -c -m 644 'vecdelta.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecdelta.cc' /usr/bin/install -c -m 644 'vecdot.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecdot.cc' /usr/bin/install -c -m 644 'vecexpr.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecexpr.h' /usr/bin/install -c -m 644 'vecexprwrap.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecexprwrap.h' /usr/bin/install -c -m 644 'vecglobs.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecglobs.cc' /usr/bin/install -c -m 644 'vecglobs.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecglobs.h' /usr/bin/install -c -m 644 'vecio.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecio.cc' /usr/bin/install -c -m 644 'veciter.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/veciter.h' /usr/bin/install -c -m 644 'vecmax.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecmax.cc' /usr/bin/install -c -m 644 'vecmin.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecmin.cc' /usr/bin/install -c -m 644 'vecnorm.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecnorm.cc' /usr/bin/install -c -m 644 'vecnorm1.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecnorm1.cc' /usr/bin/install -c -m 644 'vecpick.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecpick.cc' /usr/bin/install -c -m 644 'vecpick.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecpick.h' /usr/bin/install -c -m 644 'vecpickio.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecpickio.cc' /usr/bin/install -c -m 644 'vecpickiter.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecpickiter.h' /usr/bin/install -c -m 644 'vecsum.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecsum.cc' /usr/bin/install -c -m 644 'vector-et.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vector-et.h' /usr/bin/install -c -m 644 'vector.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vector.cc' /usr/bin/install -c -m 644 'vector.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vector.h' /usr/bin/install -c -m 644 'vecwhere.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecwhere.h' /usr/bin/install -c -m 644 'wrap-climits.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/wrap-climits.h' /usr/bin/install -c -m 644 'zero.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/zero.cc' /usr/bin/install -c -m 644 'zero.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/zero.h' /usr/bin/install -c -m 644 'matbops.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/matbops.h' /usr/bin/install -c -m 644 'mathfunc.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/mathfunc.h' /usr/bin/install -c -m 644 'matuops.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/matuops.h' /usr/bin/install -c -m 644 'promote-old.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/promote-old.h' /usr/bin/install -c -m 644 'vecbops.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecbops.cc' /usr/bin/install -c -m 644 'vecuops.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecuops.cc' /usr/bin/install -c -m 644 'vecwhere.cc' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/vecwhere.cc' test -z "//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz" || mkdir -p -- "//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz" //home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/config/install-sh -c -m 644 'gnu/bzconfig.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/blitz/gnu/bzconfig.h' make[2]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz' make[1]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz' make[1]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/random' make[1]: Nothing to be done for `install-exec-am'. test -z "//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/random" || mkdir -p -- "//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/random" /usr/bin/install -c -m 644 'F.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/random/F.h' /usr/bin/install -c -m 644 'beta.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/random/beta.h' /usr/bin/install -c -m 644 'chisquare.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/random/chisquare.h' /usr/bin/install -c -m 644 'default.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/random/default.h' /usr/bin/install -c -m 644 'discrete-uniform.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/random/discrete-uniform.h' /usr/bin/install -c -m 644 'exponential.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/random/exponential.h' /usr/bin/install -c -m 644 'gamma.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/random/gamma.h' /usr/bin/install -c -m 644 'mt.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/random/mt.h' /usr/bin/install -c -m 644 'normal.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/random/normal.h' /usr/bin/install -c -m 644 'uniform.h' '//home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/linux/include/random/uniform.h' make[1]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/random' Making distclean in doc make[1]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/doc' Making distclean in doxygen make[2]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/doc/doxygen' rm -rf .libs _libs rm -f *.lo test -z "Doxyfile" || rm -f Doxyfile test -z "Doxyfile doxygen-warning " || rm -f Doxyfile doxygen-warning rm -f libtool rm -f Makefile make[2]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/doc/doxygen' Making distclean in stencils make[2]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/doc/stencils' rm -rf .libs _libs rm -rf *.ii *.ti cxx_repository Template.dir ii_files ti_files dump-stencil *.texi rm -f *.lo test -z "" || rm -f rm -f libtool rm -f Makefile make[2]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/doc/stencils' Making distclean in examples make[2]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/doc/examples' rm -rf .libs _libs rm -rf *.ii *.ti cxx_repository Template.dir ii_files ti_files simple storage outer strideslice slicing debug output io dump xor cast range fixed *.texi *.out core.[0-9]* rm -f *.o rm -f *.lo rm -f *.tab.c test -z "" || rm -f rm -f libtool rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags rm -rf ./.deps rm -f Makefile make[2]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/doc/examples' Making distclean in . make[2]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/doc' test -z "blitz.tmp" || rm -f blitz.tmp rm -rf .libs _libs rm -rf blitz*.html rm -rf blitz.aux blitz.cp blitz.cps blitz.fn blitz.fns blitz.ky blitz.kys \ blitz.log blitz.pg blitz.pgs blitz.tmp blitz.toc blitz.tp \ blitz.tps blitz.vr blitz.vrs blitz.dvi blitz.pdf blitz.ps \ blitz.html rm -f *.lo rm -f vti.tmp test -z "" || rm -f rm -f libtool rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags make[2]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/doc' rm -f Makefile make[1]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/doc' Making distclean in benchmarks make[1]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/benchmarks' rm -rf .libs _libs rm -rf *.ii *.ti *.int.c *.s work.pc* cxx_repository Template.dir ii_files ti_files core.[0-9]* \ loop1 loop2 loop3 loop5 loop6 loop8 loop9 loop10 loop11 loop12 loop13 loop14 loop15 loop16 loop17 loop18 loop19 loop21 loop22 loop23 loop24 loop25 loop36 daxpy haney qcd stencil tinydaxpy acoustic acou3d hao-he ctime1 ctime2 ctime3 ctime4 ctime5 ctime1v ctime2v ctime3v ctime4v ctime5v rm -f *.o rm -f *.lo rm -f *.tab.c test -z "plot_benchmarks.m" || rm -f plot_benchmarks.m rm -f libtool rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags rm -rf ./.deps rm -f Makefile make[1]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/benchmarks' Making distclean in examples make[1]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/examples' rm -rf .libs _libs rm -rf *.ii *.ti cxx_repository Template.dir ii_files ti_files array cartesian cast cfd complex-test convolve curldiv deriv diff erf fixed indirect io iter matmult nested numinquire outer pauli pick polymorph prettyprint qcd rand2 random rangexpr reduce simple slicing stencil2 stencil3 stencil stencilet storage tiny transform useret where whitt rm -f *.o rm -f *.lo rm -f *.tab.c test -z "" || rm -f rm -f libtool rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags rm -rf ./.deps rm -f Makefile make[1]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/examples' Making distclean in testsuite make[1]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/testsuite' rm -rf .libs _libs rm -rf *.ii *.ti cxx_repository Template.dir ii_files ti_files Adnene-Ben-Abdallah-1 Adnene-Ben-Abdallah-2 arrayresize chris-jeffery-1 chris-jeffery-2 chris-jeffery-3 complex-test constarray contiguous copy ctors derrick-bass-1 derrick-bass-3 exprctor extract free gary-huber-1 initialize interlace iter Josef-Wagenhuber loop1 matthias-troyer-1 matthias-troyer-2 mattias-lindstroem-1 minmax minsumpow module newet Olaf-Ronneberger-1 peter-bienstman-1 peter-bienstman-2 peter-bienstman-3 peter-bienstman-4 peter-bienstman-5 peter-nordlund-1 peter-nordlund-2 peter-nordlund-3 promote qcd reduce reindex reverse shapecheck shape storage stub theodore-papadopoulo-1 tinymat tinyvec transpose troyer-genilloud Ulisses-Mello-1 wei-ku-1 where rm -f *.o rm -f *.lo rm -f *.tab.c test -z "" || rm -f rm -f libtool rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags rm -rf ./.deps rm -f Makefile make[1]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/testsuite' Making distclean in lib make[1]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/lib' test -z "libblitz.la" || rm -f libblitz.la rm -f "./so_locations" rm -rf .libs _libs rm -rf *.ii *.ti cxx_repository Template.dir ii_files ti_files rm -f *.o rm -f *.lo rm -f *.tab.c test -z "" || rm -f rm -f libtool rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags rm -rf ./.deps rm -f Makefile make[1]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/lib' Making distclean in random make[1]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/random' rm -rf .libs _libs rm -f *.lo test -z "" || rm -f rm -f libtool rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags rm -f Makefile make[1]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/random' Making distclean in blitz make[1]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz' Making distclean in array make[2]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/array' rm -rf .libs _libs rm -f *.lo test -z "" || rm -f rm -f libtool rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags rm -f Makefile make[2]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/array' Making distclean in meta make[2]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/meta' rm -rf .libs _libs rm -f *.lo test -z "" || rm -f rm -f libtool rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags rm -f Makefile make[2]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/meta' Making distclean in generate make[2]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/generate' rm -rf .libs _libs rm -rf cxx_repository ti_files ii_files genarrbops genmathfunc genvecbops genarruops genmatuops genvecuops genmatbops genpromote genvecwhere genvecbfn rm -f *.o rm -f *.lo rm -f *.tab.c test -z "" || rm -f rm -f libtool rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags rm -rf ./.deps rm -f Makefile make[2]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz/generate' Making distclean in . make[2]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz' rm -rf .libs _libs rm -rf config.h rm -f *.lo test -z "" || rm -f test -z "apple/bzconfig.h intel/bzconfig.h ibm/bzconfig.h compaq/bzconfig.h hp/bzconfig.h sgi/bzconfig.h gnu/bzconfig.h pgi/bzconfig.h pathscale/bzconfig.h kai/bzconfig.h fujitsu/bzconfig.h" || rm -f apple/bzconfig.h intel/bzconfig.h ibm/bzconfig.h compaq/bzconfig.h hp/bzconfig.h sgi/bzconfig.h gnu/bzconfig.h pgi/bzconfig.h pathscale/bzconfig.h kai/bzconfig.h fujitsu/bzconfig.h rm -f config.h stamp-h1 rm -f libtool rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags make[2]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz' rm -f Makefile make[1]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/blitz' Making distclean in bin make[1]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/bin' rm -rf .libs _libs rm -f *.lo test -z "" || rm -f rm -f libtool rm -f Makefile make[1]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9/bin' Making distclean in . make[1]: Entering directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9' rm -rf .libs _libs rm -rf *.ii *.ti cxx_repository Template.dir ii_files ti_files rm -f *.lo test -z "" || rm -f test -z "blitz.pc blitz.pc.in blitz-uninstalled.pc" || rm -f blitz.pc blitz.pc.in blitz-uninstalled.pc rm -f libtool rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags make[1]: Leaving directory `/home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty/src/blitz-0.9' rm -f config.status config.cache config.log configure.lineno configure.status.lineno rm -f Makefile //home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty stafford@linux-er3h://home/stafford/Documents/HOT_src_1.0rc6/src/3rdparty> Can't I just download some prebuilt files and install them? Where would I install those then? Quote Link to comment Share on other sites More sharing options...
phong Posted July 18, 2009 Author Share Posted July 18, 2009 Ok, what is the exact procedure for installing HOT on Linux (openSuse11) for H10? I will just do the exact steps then. Kind regards, Phong Quote Link to comment Share on other sites More sharing options...
eloop Posted July 19, 2009 Share Posted July 19, 2009 (edited) Hi Phong, Can you check that you can run the c++ compiler correctly on other HDK code, are you able to compile SOP_Star.C using hcustom ? Also can you tell me what version of g++ you are using (type "g++ -v"). I've never used opensuse so maybe some others can tell us if there are any gotchas setting up c++ for HDK use on that platform ? If that doesn't get us any further the next thing to try will be to use the latest CVS version of blitz. Thanks, Drew Ok, what is the exact procedure for installing HOT on Linux (openSuse11) for H10?I will just do the exact steps then. Kind regards, Phong Edited July 20, 2009 by eloop Quote Link to comment Share on other sites More sharing options...
dior Posted July 20, 2009 Share Posted July 20, 2009 i have the same quetion here,but i'm in win32 vc8 system~ i only got a sop_cleave.dll in my dso DOC~~ Quote Link to comment Share on other sites More sharing options...
phong Posted July 22, 2009 Author Share Posted July 22, 2009 It's version 4.3.2. I'll try compiling SOP_star.c right afterwards. Enclosed the message of "g++ -v": Using built-in specs.Target: x86_64-suse-linux Configured with: ../configure --prefix=/usr --infodir=/usr/share/info --mandir=/usr/share/man --libdir=/usr/lib64 --libexecdir=/usr/lib64 --enable-languages=c,c++,objc,fortran,obj-c++,java,ada --enable-checking=release --with-gxx-include-dir=/usr/include/c++/4.3 --enable-ssp --disable-libssp --with-bugurl=http://bugs.opensuse.org/ --with-pkgversion='SUSE Linux' --disable-libgcj --disable-libmudflap --with-slibdir=/lib64 --with-system-zlib --enable-__cxa_atexit --enable-libstdcxx-allocator=new --disable-libstdcxx-pch --enable-version-specific-runtime-libs --program-suffix=-4.3 --enable-linux-futex --without-system-libunwind --with-cpu=generic --build=x86_64-suse-linux Thread model: posix gcc version 4.3.2 [gcc-4_3-branch revision 141291] (SUSE Linux) Quote Link to comment Share on other sites More sharing options...
phong Posted July 22, 2009 Author Share Posted July 22, 2009 How do I correctly compile the SOP_star.c example on linux? Quote Link to comment Share on other sites More sharing options...
eloop Posted July 23, 2009 Share Posted July 23, 2009 How do I correctly compile the SOP_star.c example on linux? Something like this - $ cd /tmp $ cp $HFS/toolkit/samples/SOP/SOP_Star.* . $ hcustom -e SOP_Star.C Quote Link to comment Share on other sites More sharing options...
phong Posted July 23, 2009 Author Share Posted July 23, 2009 (edited) Ok, I got some problems with this. After initializing the Houdini environment with houdini_setup I still get the error: HFS: Undefined variable. when compiling SOP_Star.C with hucstom command. I also need to change directory to the bin/ directory to execute hcustom, I cannot execute that command from anywhere. cd $HFS/ does not work either, I need to type in the path manually. Maybe this helps figuring out what the problem is? Edited July 23, 2009 by phong Quote Link to comment Share on other sites More sharing options...
eloop Posted July 23, 2009 Share Posted July 23, 2009 (edited) Well you'll need to fix this before you can compile HOT, but it's not going to help get blitz compiling. I'm trying to establish that you have a functioning c++ environment that can compile standard hdk examples. It looks like you aren't initializing the environment properly. You should be able to do something like - > cd /opt/hfs10<your version> > source houdini_setup > echo $HFS > which hcustom -Drew Ok, I got some problems with this. After initializing the Houdini environment with houdini_setup I still get the error: HFS: Undefined variable. when compiling SOP_Star.C with hucstom command. I also need to change directory to the bin/ directory to execute hcustom, I cannot execute that command from anywhere. cd $HFS/ does not work either, I need to type in the path manually. Maybe this helps figuring out what the problem is? Edited July 23, 2009 by eloop Quote Link to comment Share on other sites More sharing options...
phong Posted July 24, 2009 Author Share Posted July 24, 2009 Hi eloop! Thanks a lot for your help by the way. I really need and want to get this thing running cause I really wanna try HOT instead of other non-satisfying solutions. I cannot properly compile the SOP_Star example. Here's an excerpt of the output: SOP_Star.C:134: error: ‘SOP_Star’ is not a class or namespaceSOP_Star.C: In function ‘OP_ERROR cookMySop(OP_Context&)’: SOP_Star.C:134: error: redefinition of ‘OP_ERROR cookMySop(OP_Context&)’ SOP_Star.h:134: error: ‘OP_ERROR cookMySop(OP_Context&)’ previously defined her SOP_Star.C:150: error: ‘DIVISIONS’ was not declared in this scope SOP_Star.C:151: error: ‘myTotalPoints’ was not declared in this scope SOP_Star.C:152: error: ‘myCurrPoint’ was not declared in this scope SOP_Star.C:154: error: ‘ORIENT’ was not declared in this scope SOP_Star.C:155: error: ‘NEGRADIUS’ was not declared in this scope SOP_Star.C:156: error: ‘CENTERX’ was not declared in this scope SOP_Star.C:157: error: ‘CENTERY’ was not declared in this scope SOP_Star.C:158: error: ‘CENTERZ’ was not declared in this scope SOP_Star.C:180: error: ‘error’ was not declared in this scope SOP_Star.C:188: error: ‘SOP_MESSAGE’ was not declared in this scope SOP_Star.C:188: error: ‘addWarning’ was not declared in this scope SOP_Star.C:191: error: ‘gdp’ was not declared in this scope SOP_Star.C:213: error: ‘XRADIUS’ was not declared in this scope SOP_Star.C:213: error: ‘YRADIUS’ was not declared in this scope SOP_Star.C:226: error: ‘GU_SPrimitive’ was not declared in this scope SOP_Star.C:233: error: ‘error’ was not declared in this scope Compile failed So I guess my compiler is not properly set up since cause there are a lot of errors that result from probably not finding the header files? What is that blitz thing anyway? Do I really need it? By the way, do you fully understand the HOT displacement shader part (or the linearized Bernoulli's equation and the dispersion relation in Jerry Tessendorf's paper)? Because if yes, I'd try to translate the concepts to an rsl shader with external help. Quote Link to comment Share on other sites More sharing options...
eloop Posted July 24, 2009 Share Posted July 24, 2009 Hi Phong, I'm stumped, it would seem that something is askew with your system setup, I would suggest that SideFX support are the people to talk to since your problem at this point isn't really HOT specific. Google for "blitz++", and yes you need it. I have a pretty good understanding of the HOT displacement shader, I wrote it. Moritz Moeller contributed a renderman shadeop to the HOT. See - I've included his source in the latest HOT code which is hosted on code.google.com - http://code.google.com/p/houdini-ocean-toolkit/source/browse/#hg/src/misc Unfortunately this will require you understand how to use cmake, another fun tool. Sorry this isn't all easier but I already have a day job, I think you are beginning to get an idea why FX houses have programmer/TD's on staff :-) -Drew Hi eloop! Thanks a lot for your help by the way. I really need and want to get this thing running cause I really wanna try HOT instead of other non-satisfying solutions. I cannot properly compile the SOP_Star example. Here's an excerpt of the output: So I guess my compiler is not properly set up since cause there are a lot of errors that result from probably not finding the header files? What is that blitz thing anyway? Do I really need it? By the way, do you fully understand the HOT displacement shader part (or the linearized Bernoulli's equation and the dispersion relation in Jerry Tessendorf's paper)? Because if yes, I'd try to translate the concepts to an rsl shader with external help. Quote Link to comment Share on other sites More sharing options...
phong Posted July 24, 2009 Author Share Posted July 24, 2009 Wow! I didn't know you were the one who wrote all this! I hope sideFX can help me on this issue, at least I posted on the forums. Would you mind if I asked you one day about the dispersion relation and the linearization of Bernoulli's equation? I know this is quite off topic then, but there were some points I did not quite get but which I'd like to fully understand. Quote Link to comment Share on other sites More sharing options...
Hyperion Posted August 3, 2009 Share Posted August 3, 2009 Hi Mr/Dr. Whitehouse. First of all, many thanks for such an excellence in computer programming and simulation. I am trying to compile HOT in my Mac. I have follow the instructions shown here: http://anusf.anu.edu.au/~drw900/houdini/ocean/docs/#osx " cd <where you extracted the HOT source>/src/3rdparty ./build_osx.sh # now would be a good time for a latte ... cd .. ./compile_osx.sh " but I have encountered several problems: Here´s the log from the compile process: " Gondor:src user$ ./compile_osx.sh Building and installing the Houdini Ocean Toolkit... Linking with 'libblitz' Linking with 'libfftw3f' g++ -DUT_DSO_TAGINFO='"3262197cbf075a1131862a87493e9eee6542daf3ce2e99fa6da8f77b5847f185379b21c0d07c7334432be2e667bb645b4beee610fedae355440c2de177f891bc429445a0ff924994a3268d4a1ea011fcfe1d90a2e5"' -DVERSION=\"10.0.295\" -DDLLEXPORT= -D_GNU_SOURCE -DMBSD -DMBSD_COCOA -DMBSD_INTEL -arch x86_64 -DAMD64 -fPIC -DSIZEOF_VOID_P=8 -DSESI_LITTLE_ENDIAN -DENABLE_THREADS -DUSE_PTHREADS -D_REENTRANT -D_FILE_OFFSET_BITS=64 -fobjc-gc-only -c -I./3rdparty/include -I./3rdparty/osx/include -DGCC4 -DGCC3 -Wno-deprecated -I/Library/Frameworks/Houdini.framework/Versions/10.0.295/Resources/toolkit/include -I/Library/Frameworks/Houdini.framework/Versions/10.0.295/Resources/toolkit/include/htools -Wall -W -Wno-parentheses -Wno-sign-compare -Wno-reorder -Wno-uninitialized -Wunused -Wno-unused-parameter -O2 -DMAKING_DSO -o SOP_Cleave.o SOP_Cleave.C cc1plus: warning: command line option "-fobjc-gc-only" is valid for ObjC/ObjC++ but not for C++ g++ -bundle SOP_Cleave.o -arch x86_64 -fobjc-gc-only -I./3rdparty/include -I./3rdparty/osx/include -L./3rdparty/osx/lib -lblitz -lfftw3f -framework OpenGL -framework Cocoa -rpath,@loader_path/Libraries -Wl,-rpath,/Library/Frameworks/Houdini.framework/Versions/10.0.295/Libraries -L/Library/Frameworks/Houdini.framework/Versions/10.0.295/Libraries -L/Library/Frameworks/Houdini.framework/Versions/10.0.295/Resources/Frameworks/Houdini.framework/Versions/10.0.295/Libraries -F/Library/Frameworks/Houdini.framework/Versions/10.0.295/Resources/Frameworks -framework Houdini -o /Users/user/Library/Preferences/houdini/10.0/dso/SOP_Cleave.dylib ld: in /Library/Frameworks//Python.framework/Python, missing required architecture x86_64 in file collect2: ld returned 1 exit status g++ -DUT_DSO_TAGINFO='"3262197cbf075a1131862a87493e9eee6542daf3ce2e99fa6da8f77b5847f185379b21c0d07c7334432be2e667bb645b4beee610fedae355440c2ced77f891bc429445a0ff924994a3268d4a1ea011fcfe1d90a2e5"' -DVERSION=\"10.0.295\" -DDLLEXPORT= -D_GNU_SOURCE -DMBSD -DMBSD_COCOA -DMBSD_INTEL -arch x86_64 -DAMD64 -fPIC -DSIZEOF_VOID_P=8 -DSESI_LITTLE_ENDIAN -DENABLE_THREADS -DUSE_PTHREADS -D_REENTRANT -D_FILE_OFFSET_BITS=64 -fobjc-gc-only -c -I./3rdparty/include -I./3rdparty/osx/include -DGCC4 -DGCC3 -Wno-deprecated -I/Library/Frameworks/Houdini.framework/Versions/10.0.295/Resources/toolkit/include -I/Library/Frameworks/Houdini.framework/Versions/10.0.295/Resources/toolkit/include/htools -Wall -W -Wno-parentheses -Wno-sign-compare -Wno-reorder -Wno-uninitialized -Wunused -Wno-unused-parameter -O2 -DMAKING_DSO -o SOP_Ocean.o SOP_Ocean.C cc1plus: warning: command line option "-fobjc-gc-only" is valid for ObjC/ObjC++ but not for C++ g++ -bundle SOP_Ocean.o -arch x86_64 -fobjc-gc-only -I./3rdparty/include -I./3rdparty/osx/include -L./3rdparty/osx/lib -lblitz -lfftw3f -framework OpenGL -framework Cocoa -rpath,@loader_path/Libraries -Wl,-rpath,/Library/Frameworks/Houdini.framework/Versions/10.0.295/Libraries -L/Library/Frameworks/Houdini.framework/Versions/10.0.295/Libraries -L/Library/Frameworks/Houdini.framework/Versions/10.0.295/Resources/Frameworks/Houdini.framework/Versions/10.0.295/Libraries -F/Library/Frameworks/Houdini.framework/Versions/10.0.295/Resources/Frameworks -framework Houdini -o /Users/user/Library/Preferences/houdini/10.0/dso/SOP_Ocean.dylib ld: in /Library/Frameworks//Python.framework/Python, missing required architecture x86_64 in file collect2: ld returned 1 exit status g++ -DUT_DSO_TAGINFO='"3262197cbf075a1131862a87493e9eee6542daf3ce2e99fa6da8f77b5847f185379b21c0d07c7334432be2e667bb645b4beee610fedae355440c2fe977f891bc429445a0ff924994a3268d4a1ea011fcfe1d90a2e5"' -DVERSION=\"10.0.295\" -DDLLEXPORT= -D_GNU_SOURCE -DMBSD -DMBSD_COCOA -DMBSD_INTEL -arch x86_64 -DAMD64 -fPIC -DSIZEOF_VOID_P=8 -DSESI_LITTLE_ENDIAN -DENABLE_THREADS -DUSE_PTHREADS -D_REENTRANT -D_FILE_OFFSET_BITS=64 -fobjc-gc-only -c -I./3rdparty/include -I./3rdparty/osx/include -DGCC4 -DGCC3 -Wno-deprecated -I/Library/Frameworks/Houdini.framework/Versions/10.0.295/Resources/toolkit/include -I/Library/Frameworks/Houdini.framework/Versions/10.0.295/Resources/toolkit/include/htools -Wall -W -Wno-parentheses -Wno-sign-compare -Wno-reorder -Wno-uninitialized -Wunused -Wno-unused-parameter -O2 -DMAKING_DSO -o VEX_Ocean.o VEX_Ocean.C cc1plus: warning: command line option "-fobjc-gc-only" is valid for ObjC/ObjC++ but not for C++ g++ -bundle VEX_Ocean.o -arch x86_64 -fobjc-gc-only -I./3rdparty/include -I./3rdparty/osx/include -L./3rdparty/osx/lib -lblitz -lfftw3f -framework OpenGL -framework Cocoa -rpath,@loader_path/Libraries -Wl,-rpath,/Library/Frameworks/Houdini.framework/Versions/10.0.295/Libraries -L/Library/Frameworks/Houdini.framework/Versions/10.0.295/Libraries -L/Library/Frameworks/Houdini.framework/Versions/10.0.295/Resources/Frameworks/Houdini.framework/Versions/10.0.295/Libraries -F/Library/Frameworks/Houdini.framework/Versions/10.0.295/Resources/Frameworks -framework Houdini -o /Users/user/Library/Preferences/houdini/10.0/dso/VEX_Ocean.dylib ld: in /Library/Frameworks//Python.framework/Python, missing required architecture x86_64 in file collect2: ld returned 1 exit status Done compiling and installing the DSO's to /dso. Done installing the icon files to /Users/user/Library/Preferences/houdini/10.0/config/Icons. Done installing and editing /Users/user/Library/Preferences/houdini/10.0/vex/VEXdso. All done. You can now try loading ../examples_and_otl/sop_simple.hip Gondor:src user$ " ----------------------------------------------------------------------------- SYSTEM CONFIGURATION: Mac Pro 2 x 2.66 GHz Dual-Core Intel Xeon 6 GB RAM OSX 10.5.7 Developer tools installed, Xcode version 3.0, gcc v.4 MacPython 3.1 Houdini apprentice HD (with paid license), v10.0.295 ----------------------------------------------------------------------------- It seems that Python needs to be a 64bit version in order to work with hcustom and this compilation. Is that right? If so, should I pre-compile a custom_64bits version of Python in order to compile HOT for my machine ? Any help would be apreciated. Quote Link to comment Share on other sites More sharing options...
