How To Get Light Specific Extra Image Planes
I have a scene with 10 lights. I want 10 passes with illumination by each individual light.
I know that for 3 point lighting we can use RGB method. But that won't help with more than 3 lights. I am trying to do it with mantra node and Extra Image Planes option. There is an option called, Export variable for each Light. I am giving "Cf" as a vex variable and " Export variable for each Light" ON. It creates 10 channels but no information in it.
Plz reply if anybody knows how to do it.
You need to have an export parameter that is inside an illuminance loop (check out the help on the mantra node). I don't know what they are called (or if they exist) in the normal lighting model vops.
An example of it working is attached. Search the forums for "illuminance loop", there are a few threads out there.
perLightExport.hipnc
The option to export per-light image planes on the Mantra ROP will only work if you've made your own illuminance loop that exports each light's contribution before it gets summed. The default LightingModel VOP, Lambert VOP and Specular VOP's outputs combine all of your light's contribution in their export variables.
if you've already written your shaders properly, then all you have to do is toggle the "Export variable for each light" option and it will work.
Edited by Alanw
