what is the meaning of the expression in the sop solver example? Thank
maphysart
I try the dentingwithpop sop solver example hip in the help file. Inside the dopnetwork solvergeo, there are two expression I can not understand.
1st. in the copy_per_impact node:
dopnumrecords("../..", stamp("../OUT", "OBJID", 0), "Feedback", "Impacts")
2nd in the merge_dop_object node:
`stamps("../OUT", "DATAPATH", "../..:dentme/Geometry")`
so what is the meaning of OBJID? I am confused because the OUT is only a null node. It does not have any attributes or parameters called OBJID. Besides, What is DATAPATH? I could not find it in the global or standard variables. Futhermore, why use ../..: , what is the meaning of ":" ?
Thanks a lot. I hope you can give me some hints.
Thanks a lot to Michael.
I found DATAPATH and OBJID, and know more about Sop solver. They are global parameters, so I did not find them in the OUT node. :D
But there are still some questions:
I add a float parameter in the copy_per_impact node within geosolver sop network.
and put in
`stamp("../OUT", "ST", 0)`
I wish to get the simulation time from the dent outside this sop network. But it did not work.
Besides, I searched "path" or "path syntax" in the help doc and found nothing. Could you or anybody give me more detail about the path syntax? Thanks .
