win32vc8 i only got sop_cleave.dll
dior
hi guys ~i got some troubles in hot~ i setup hot follow help.everthing is ok ,but only got sop_cleave.dll~ my system is win32vc8,houdini version is 10.0.295,hot version is HOT_src_1.0rc6 ~
Edited by dior
  • Downvote 1
Hi Dior,
Can you post the output of the compile script.
-Drew
hi guys ~i got some troubles in hot~ i setup hot follow help.everthing is ok ,but only got sop_cleave.dll~ my system is win32vc8,houdini version is 10.0.295,hot version is HOT_src_1.0rc6 ~ i will upload some pics~ i install hot otl but something is wrong~post-4564-1248078791.jpg
Hi Dior,
-Drew
thanks eloop
Administrator@MICROSOF-23ECCF ~
$ df
Filesystem           1k-blocks      Used Available Use% Mounted on
C:\cygwin\usr\X11R6\lib\X11\fonts
                      29288208  25266608   4021600  87% /usr/X11R6/lib/X11/font
C:\cygwin\bin         29288208  25266608   4021600  87% /usr/bin
C:\cygwin\lib         29288208  25266608   4021600  87% /usr/lib
C:\cygwin             29288208  25266608   4021600  87% /
c:                    29288208  25266608   4021600  87% /cygdrive/c
d:                    58597055  56072484   2524572  96% /cygdrive/d
e:                    67488576  67117312    371264 100% /cygdrive/e
f:                    58052704  54663808   3388896  95% /cygdrive/f
$ cd /cygdrive/d
Administrator@MICROSOF-23ECCF /cygdrive/d
$ cd houdini/hot/hot_src_1.0rc6/src
Administrator@MICROSOF-23ECCF /cygdrive/d/houdini/hot/hot_src_1.0rc6/src
$ ./compile_win32.sh
Building and installing the Houdini Ocean Toolkit...
Linking with 'blitz.lib'
Linking with 'libfftw3f-3.lib'
Making 'SOP_Ocean.o' and 'c:/DOCUME~1/ADMINI~1/Desktop/houdini10.0/dso\SOP_Ocea
.dll' from 'SOP_Ocean.C'
Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.42 for 80x86
Copyright (C) Microsoft Corporation.  All rights reserved.
SOP_Ocean.C
3rdparty/win32\blitz/blitz.h(110) : fatal error C1083: Cannot open include file
 'pthread.h': No such file or directory
Making 'VEX_Ocean.o' and 'c:/DOCUME~1/ADMINI~1/Desktop/houdini10.0/dso\VEX_Ocea
.dll' from 'VEX_Ocean.C'
VEX_Ocean.C
Making 'SOP_Cleave.o' and 'c:/DOCUME~1/ADMINI~1/Desktop/houdini10.0/dso\SOP_Cle
ve.dll' from 'SOP_Cleave.C'
SOP_Cleave.C
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/toolkit/include\SYS/SYS_Math.h(376) : warning
C4996: 'hypot' was declared deprecated
        C:/Program Files/Microsoft Visual Studio 8/VC/include\math.h(455) : see
declaration of 'hypot'
        Message: 'The POSIX name for this item is deprecated. Instead, use the
SO C++ conformant name: _hypot. See online help for details.'
d:\program files\side effects software\houdini 10.0.295\toolkit\include\ut\UT_S
ring.h(67) : warning C4996: 'strdup' was declared deprecated
        C:/Program Files/Microsoft Visual Studio 8/VC/include\string.h(205) : s
e declaration of 'strdup'
SO C++ conformant name: _strdup. See online help for details.'
ring.h(117) : warning C4996: 'strdup' was declared deprecated
ring.h(125) : warning C4996: 'strdup' was declared deprecated
ring.h(191) : warning C4996: 'strcpy' was declared deprecated
        C:/Program Files/Microsoft Visual Studio 8/VC/include\string.h(73) : se
 declaration of 'strcpy'
        Message: 'This function or variable may be unsafe. Consider using strcp
_s instead. To disable deprecation, use _CRT_SECURE_NO_DEPRECATE. See online he
p for details.'
d:\program files\side effects software\houdini 10.0.295\toolkit\include\ut\UT_W
rkBuffer.h(138) : warning C4996: 'strncpy' was declared deprecated
        C:/Program Files/Microsoft Visual Studio 8/VC/include\string.h(156) : s
e declaration of 'strncpy'
        Message: 'This function or variable may be unsafe. Consider using strnc
y_s instead. To disable deprecation, use _CRT_SECURE_NO_DEPRECATE. See online h
lp for details.'
rkBuffer.h(172) : warning C4996: 'strncat' was declared deprecated
        C:/Program Files/Microsoft Visual Studio 8/VC/include\string.h(143) : s
e declaration of 'strncat'
t_s instead. To disable deprecation, use _CRT_SECURE_NO_DEPRECATE. See online h
lp for details.'
rkBuffer.h(196) : warning C4996: 'strdup' was declared deprecated
d:\program files\side effects software\houdini 10.0.295\toolkit\include\ut\UT_H
sh.h(69) : warning C4996: 'strdup' was declared deprecated
sh.h(85) : warning C4996: 'strdup' was declared deprecated
Microsoft (R) Incremental Linker Version 8.00.50727.42
/out:SOP_Cleave.dll
/dll
/implib:SOP_Cleave.lib
"/libpath:C:/Program Files/Microsoft Visual Studio 8/VC/lib"
"/libpath:C:/Program Files/Microsoft Visual Studio 8/VC/PlatformSDK/lib"
/libpath:3rdparty/win32
blitz.lib
libfftw3f-3.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libarray.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libAU.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libBM.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libBR.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libBV.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libCH.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libCHOP.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libCHOPNET.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libCHOPZ.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libCHUI.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libCL.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libCLO.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libCMD.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libCOP2.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libCOPNET.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libCOPZ.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libCPUI.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libCVEX.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libDAE.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libDD.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libDM.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libDOP.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libDOPZ.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libdxf.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libEXPR.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libFBX.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libFS.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libFUI.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libFUSE.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libGAS.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libGB.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libGD.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libGDT.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libGEO.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libGOP.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libGP.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libGQ.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libGR.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libGR2D.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libGU.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libGUI.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libGVEX.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libHOM.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libHOMF.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libIFD.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libIM.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libIMG.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libIMG3D.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libIMGUI.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libIMH.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libIMP.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libIMS.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libIPR.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libJEDI.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libJIVE.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libjpeg.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libKIN.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libLA.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libLM.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libMATUI.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libMC.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libMCS.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libMDS.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libMGR.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libMH.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libMIDI.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libMOT.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libMPI.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libMPS.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libMSS.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libMT.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libMV.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libMWS.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libOBJ.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libOH.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libOP.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libOP3D.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libopenexrh.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libOPUI.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libpaudio.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libPBR.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libPI.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libpngh.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libPOP.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libPOPNET.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libPOPUI.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libPOPZ.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libPRM.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libPSI2.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libPXL.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libPY.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libRBD.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libRE.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libROP.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libRU.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libSHLF.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libSHOP.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libSI.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libSIM.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libSIMZ.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libSOHO.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libSOP.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libSOPZ.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libSS.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libSYS.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libTAKE.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libTBF.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libTHOR.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libtiff.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libTIL.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libtools.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libTS.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libUI.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libUT.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libVEX.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libVM.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libVMAT.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libVOP.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libVOPNET.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libVPRM.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libVRAY.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libWIRE.a
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/audiere.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/audiere_d.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/boost_thread-vc80-mt-1_
3_1.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/boost_thread-vc80-mt-gd
1_33_1.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/fbxsdk_md.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/fbxsdk_md_d.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libasprintf.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libasprintf_d.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libcharset.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libcharset_d.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libglib-2.0.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libglib-2.0_d.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libglibmm-2.4.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libglibmm-2.4_d.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libgmodule-2.0.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libgmodule-2.0_d.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libgobject-2.0.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libgobject-2.0_d.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libgthread-2.0.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libgthread-2.0_d.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libiconv.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libiconv_d.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libintl.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libintl_d.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libsigc-2.0.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libsigc-2.0_d.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libsndfile.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libsndfile_d.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libxml++-2.6.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libxml++-2.6_d.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libxml2.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/libxml2_d.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/python25.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/python25_d.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/sqlite3.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/sqlite3_d.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/zdll.lib
d:/PROGRA~1/SIDEEF~1/HOUDIN~1.295/custom/houdini/dsolib/zdll_d.lib
-out:c:/DOCUME~1/ADMINI~1/Desktop/houdini10.0/dso/SOP_Cleave.dll
SOP_Cleave.o
   正在创建库 SOP_Cleave.lib 和对象 SOP_Cleave.exp
Done compiling and installing the DSO's to /dso.
Done installing the icon files to /config/Icons.
Done installing and editing /vex/VEXdso.
All done. You can now try loading ../examples_and_otl/sop_simple.hip
Edited by dior
i think the problem is here.
SOP_Ocean.C
anyone can help me?
thank dior
Edited by dior
Just remembered this.... take a look at
http://forums.odforce.net/index.php?/topic/8792-vc8-win32-houdini-95379-compile-error-blitz/page__view__findpost__p__58047
Does that fix the problem ?
This is fixed in my development version which uses a newer version of blitz++ that has reentrancy support for win32.
-Drew
Edited by eloop
-Drew
thanks eloop it's very kind of you~
i'm just a artist,not good at compile can u tell me some detail? i'v looked ur link,but my qestion is different from him. u means commenting out the "#define BZ_THREADSAFE" line in Ocean.h. Or better replace it with
#ifndef WIN32
#endif
right?
Yep, try that.
-Drew
#ifndef WIN32
#endif
right?
Yep, try that.
-Drew
really thx eloop,l love u so much~ u r a strong man~ i got 3 .dll ~but when load hot otl ,i still get same trouble as my first pic~ when i render with mantra i also get an error
Edited by dior
You probably now just need to make sure the fftw dll (in src/3rdparty/win32) is installed somewhere on your executable path, a good place is to copy them into the directory $HFS/bin which is where houdini.exe is kept. We're close now.
-Drew
Edited by eloop
-Drew
i just decompression fftw-3.2-dll foder and got somethings(post-4564-124852407682_thumb.jpg).I copy all of them to my houdini path(D:\Program Files\Side Effects Software\Houdini 10.0.249.5\bin),but the problem still. do i miss something?
i open the vex_ocean_displace node,i can see code of it.when i press test compile i got some error.(post-4564-124852528919_thumb.jpg).This is a hot_ocean_eval error.(post-4564-124852543118_thumb.jpg)
sorry my poor english~
thanks dior
Edited by dior
At this point you should be able to read all the example files, no ?
-Drew
thanks dior
-Drew
d
yes eloop,but i can only use sop_cleave and sop_ocean. the vex displace shader and vop_ocean_eval are not normal~i can't use them~
So what happens when you open examples/vopsop_foamparts.hip ?
-Drew
d
Can you try
> cat ~/houdini10.0/vex/VEXdso
You should see
VEX_Ocean.dll
If not
> mkdir ~/houdini10.0/vex
> cp src/VEXdso_win32 ~/houdini10.0/vex/VEXdso
-Drew
take a look man.here is my result.maybe something with vex code~
Edited by eloop
Can you try
You should see
VEX_Ocean.dll
If not
-Drew
frist of all,i just hava dos folder and i put them in itpost-4564-124878117267_thumb.jpg~ i dont have vexdso folder,so i follow your steps and creat a vex and vexdso folderpost-4564-124878119613_thumb.jpg~am i right?
VEXdso is a file, not a folder. The VEXdso_win32 file needs to be copied to the %HOME%\houdini10.0\vex folder and renamed VEXdso.
-Drew
