WIP Ocean
varomix
Hi
I've been doing this Ocean shading for a little while and would like some feedback
so far I'm way happier with the results than last week :D , which is always good.
I'm using Houdini Ocean Toolkit(HOT) , for shading is a modified version of the basic liquid shader, I'm also using 3 passes of foam and some more colors mixed up at SOP level that are taken by the shader for the final color, also the shader takes the foam areas and adds extra noise just in those areas.
I still need to add particle foam on top of that, but I wanted to make as much as I could in the surface first.
Thank you in advance for any comments and suggestions
