Guest Swann Posted July 31, 2009 Share Posted July 31, 2009 why not just multiply by rot matrix and add P difference? Have you looked at example in 7 post here ? why the hocus-pocus with matrix conversion? Learning ? As I sad, I was reading book and now I tryed do it practicaly. Quote Link to comment Share on other sites More sharing options...
anim Posted July 31, 2009 Share Posted July 31, 2009 i was assuming you are trying to do what you've done in 7th post just with one VOP, which you can exactly just like that, sorry if i misunderstand you learning is the best reason, sorry for that too Quote Link to comment Share on other sites More sharing options...
raven0us Posted August 1, 2009 Author Share Posted August 1, 2009 Hi SWANN, other work...back to odforce.. back to my project. Didn't try your solutions on my character's hair yet.Even if I don't it's great learning material and can be put to use for some other cooler stuff... Like anim says aligning the 1st and 2nd points can be useful for hair...so far I haven't had to tho. Great stuff... Quote Link to comment Share on other sites More sharing options...
raven0us Posted August 3, 2009 Author Share Posted August 3, 2009 (edited) I somehow got the pigtails to work....using forEach ...copy...but it was not a clean solution...I suppose it worked because each pigtail was facing more or less in the same direction... But things were a lot different with hair on the character's head...since they were all growing in different directions. So SWANN's solution (the simpler version posted) is what I'm using now. Still learning. modified it to get the 1st and 2nd (not the last) points aligned...So now the 1st and 2nd will align with the normal...and the rest will be the "styled" hair. mmmm..there is still that orientation problem... Curves_rotfix01.hipnc Edited August 3, 2009 by raven0us Quote Link to comment Share on other sites More sharing options...
raven0us Posted August 4, 2009 Author Share Posted August 4, 2009 (edited) solution edward..Owl... http://forums.odforce.net/index.php?showtopic=7813&st=0&p=52188entry52188 Curves_rotfix03.hipnc Edited August 4, 2009 by raven0us Quote Link to comment Share on other sites More sharing options...
