Dennis Sedov Posted July 25, 2009 Share Posted July 25, 2009 I am trying to render particles as points, but have hard time finding how to define point size. I assume that I need to use "Attribute Create", and provide the value there, but I cant find the name of an attribute. Quote Link to comment Share on other sites More sharing options...
brianburke Posted July 26, 2009 Share Posted July 26, 2009 Yo dude. In the Attribute SOP, you can go to the RenderMan tab and add the attributes and set the type appropriately - the attribute for particle scale is "width" of type varying float. Its even easier tho if you add PScale in the way you would to control the look of a Mantra render and just check "Add Default Mappings" in the RenderMan tab of the Attribute SOP. I'll convert all of the normal attributes to ones that RenderMan finds to be tasty. Quote Link to comment Share on other sites More sharing options...
Dennis Sedov Posted July 27, 2009 Author Share Posted July 27, 2009 Thanks alot, this worked perfectly! Yo dude. In the Attribute SOP, you can go to the RenderMan tab and add the attributes and set the type appropriately - the attribute for particle scale is "width" of type varying float. Its even easier tho if you add PScale in the way you would to control the look of a Mantra render and just check "Add Default Mappings" in the RenderMan tab of the Attribute SOP. I'll convert all of the normal attributes to ones that RenderMan finds to be tasty. Quote Link to comment Share on other sites More sharing options...
