Lines between sets of points
beeemtee
Hey,
i would like to connect the points of two sets with the same number of points, with straight lines. i did it with a foreach sop but i'm sure that it is not the easiest and most effective way to do this. it's rather slow..
how would you achieve the same?
thanks
bmt
No need for the Sort SOP.
Many SOPs that rebuild geometry have two options:
Skip every Nth point
or
Group of N points
Skip every Nth point is used if you want to work on a series of primitives with the same point count and you want to work on the same vertex on each primitive.
Two curves can have their points easily connected by using the Skip every Nth point where the skip number is the total number of points per curve in the Add SOP.
See the hip file for two easy ways to do that.
connectPoints_v02.hipnc
