cspears2002 Posted July 28, 2009 Share Posted July 28, 2009 I am working on an electron microscope scene that includes a diatom sitting on surface. Both the diatom and surface are partially encrusted with some sort of crystal/mineral deposit. Eventually I want to add some microbes that swim around. My main concern right now is render time. The crystals take a while to render. Plus, my scene file is getting bigger! The size of the scene file might be caused by a bug in Houdini Apprentice 10.0.295. However, I noticed that I just have a lot of stuff happening in my scene! Let me know what you think! microworld_v03_4.hipnc Quote Link to comment Share on other sites More sharing options...
beeemtee Posted July 30, 2009 Share Posted July 30, 2009 (edited) there was a bug in 295, which has been fixed since. to check that if this is your problem, see if there is a strange meaningless and very long string in the lut string in the color correction tab of the color settings window. if there is, then i recommend you to switch to the daily build, and delete that string. cheers bmt Edited July 30, 2009 by beeemtee Quote Link to comment Share on other sites More sharing options...
cspears2002 Posted July 31, 2009 Author Share Posted July 31, 2009 Wow. I see what you mean. This is turning in to a real pain to fix. Can I fix it by hacking the hipnc file? That might be easier. Quote Link to comment Share on other sites More sharing options...
cspears2002 Posted August 1, 2009 Author Share Posted August 1, 2009 Wow. I see what you mean. This is turning in to a real pain to fix. Can I fix it by hacking the hipnc file? That might be easier. Ok I figured it out. I went to the preferences directory and removed the string from the colors pref file. Quote Link to comment Share on other sites More sharing options...
