mattd Posted July 30, 2009 Share Posted July 30, 2009 Ok, I am coming down with a cold so I am not thinking totally straight... I have been searching but most related topics are either on linux or via cygwin, I have neither I need to distribute a chain of complex SOP ops that write to a bgeo sequence across a farm using Muster, and it only supports single dos commands. I need to run a command like: hscript render -f 1 10 /obj/geo/out/geometry In muster I have to use a wildcard to replace the 1 and 10 to do the slicing. Therefore, calling an external script does not work. I hope the question makes sense. MD Quote Link to comment Share on other sites More sharing options...
stevenong Posted July 30, 2009 Share Posted July 30, 2009 Hi, Have you tried using hrender instead? hrender -h will give you the options. Cheers! steven Quote Link to comment Share on other sites More sharing options...
mattd Posted July 30, 2009 Author Share Posted July 30, 2009 hrender needs csh to run, and I cannot get the render queue to run it properly from a single dos command. I can start the csh, but then i cannot pass the command with the frame overrides. however, I did find a python solution, and I have it working now. I'll post it in a bit to help future queries. MD Hi, Have you tried using hrender instead? hrender -h will give you the options. Cheers! steven Quote Link to comment Share on other sites More sharing options...
mattd Posted July 30, 2009 Author Share Posted July 30, 2009 ok here is a solution: in muster, I have a 'custom job' that launches cmd.exe muster then wants a arguments string, with <SF> and <EF> to distribute chunks to machines. these have dos backslashes /C "C:\Program Files\Side Effects Software\Houdini 9.5.379\bin\hython" \\10.1.2.10\chicagowip\_PROJECTS\2009\blahblah\06_3D\houdini\render.py <SF> <EF> here is the script, with hard coded paths to get this running quick: import sys, os, hou args = sys.argv start = args.pop() end = args.pop() os.chdir("\\\\10.1.2.10\\chicagowip\\_PROJECTS\\2009\\blahblah\\06_3D\houdini") hou.hipFile.load("blahblah.hip") hou.hscript("render -V -f " + start + " " + end + " /obj/particle_emitter1/ropnet1/mentalray1") I know I should use the new HOM render command, but I have not gotten into it quite yet. Hope it helps someone, MD 1 Quote Link to comment Share on other sites More sharing options...
