customRamp VOPSOP
itriix
hello everyone, i am trying to make a customRamp VOPSOP, so that I don't have to keep building one for every particular reason that i want one for. "example, plugging in alpha, and using a ramp to change the values, or plugging in a noise function, and using a ramp to visually see the values that i want to output"...
well you got the idea, there are so many ways to use the ramp... but here is my issue. For now, I always just create a PARAMETER node inside of the VOP, "to essentially import the parameter that i want", and then have that plugged into the ramp, and then have the output of the ramp plugged into another PARAMATER node, that's used for EXPORTING the paramater.
how can I make it so that i don't have to always create a new paramater vop (for import) and new paramater vop (for exporting) every single time? Is there some way that I can use a more friendly approach? Something where for example, up in SOPS, i can have a paramater on the vop, that allows me to TYPE IN THE ATTRIBUTE NAME that i'm going to want to use? and then have the paramater vop import and paramater vop export, update to that param name?
thanks,
Jonathan
