Making a wind chime with POPs
Has anyone made anything like a chandelier where the individual chains collide when you animate the plank they're bolted to?
I'm trying to:
- connect 10 to 20 cylinders (the links in this chain) with loose ball-joints;
- attach the 'top' cylinder to a plank so the rest ot the chain hangs from it;
- get dozens of these chains 'hanging' from the same plank (basically an instance at each point)
- animate the plank to generate RBD within each chain and among adjacent chains.
IS THERE A TUTORIAL ANYWHERE???
I'm okay with RBD using separate geometry objects at object level, but this level of instancing and interaction looks like a job for POPs.
Help.
