itriix Posted August 9, 2009 Share Posted August 9, 2009 Just wanted to tell everyone that I found a great plugin called: OE BLASTER http://scripts.zbuff...ster/index.html I've verified it to work on MAC LEOPARD 10.5.7 with MAYA 2009 and Houdini 10.249.5!!!!!!!!!! In the past i've used, objExportSeries.mel and OBJSeqExport.mel with "okay results" in the past, but recently, they haven't been working for some reason or another. And so, had to find a new method. this one works great and i highly recommend it if you're having problems exporting to OBJ sequence. I would opt to go for FBX for it's cleanliness but there are still issues with houdini importing FBX correctly from MAC Cheers, Jonathan Quote Link to comment Share on other sites More sharing options...
pclaes Posted August 9, 2009 Share Posted August 9, 2009 Just wanted to tell everyone that I found a great plugin called: OE BLASTER http://scripts.zbuff...ster/index.html I've verified it to work on MAC LEOPARD 10.5.7 with MAYA 2009 and Houdini 10.249.5!!!!!!!!!! In the past i've used, objExportSeries.mel and OBJSeqExport.mel with "okay results" in the past, but recently, they haven't been working for some reason or another. And so, had to find a new method. this one works great and i highly recommend it if you're having problems exporting to OBJ sequence. I would opt to go for FBX for it's cleanliness but there are still issues with houdini importing FBX correctly from MAC Cheers, Jonathan Thanks for this, I'm sure it will come in handy. Quote Link to comment Share on other sites More sharing options...
