Unik Posted August 13, 2009 Share Posted August 13, 2009 Hey guys... I was wondering that in the "Math operator" what is the difference between "Combine Channel" and "Combine CHOPS"... both seems to so the same thing... Quote Link to comment Share on other sites More sharing options...
edward Posted August 13, 2009 Share Posted August 13, 2009 http://www.sidefx.com/docs/houdini10.0/nodes/chop/math Combine ChannelsA menu of operations that is performed between the channels of a single input CHOP, for each input. Combine CHOPs A menu of operations that is performed between the input CHOPs, combining several CHOPs into one. Quote Link to comment Share on other sites More sharing options...
Unik Posted August 13, 2009 Author Share Posted August 13, 2009 Does that means combine CHOPS will combine two or more CHOP networks... but combine Channels will combine operators of the same CHOPnet.... Quote Link to comment Share on other sites More sharing options...
edward Posted August 13, 2009 Share Posted August 13, 2009 Combine CHOPs will combine channels across two or more CHOP nodes Quote Link to comment Share on other sites More sharing options...
Unik Posted August 13, 2009 Author Share Posted August 13, 2009 (edited) okay...but what should I do in a case like this... I mean which one is appropriate?? Edited August 13, 2009 by Unik Quote Link to comment Share on other sites More sharing options...
edward Posted August 13, 2009 Share Posted August 13, 2009 Er, well, it depends on what you want to do. Assuming that you want to combine the two input CHOPs in some way, then yes, use Combine CHOPs. Quote Link to comment Share on other sites More sharing options...
Unik Posted August 13, 2009 Author Share Posted August 13, 2009 ahh... okay... actually both of them were working... so i was not not sure to use which one but thanxx for you reply... Quote Link to comment Share on other sites More sharing options...
edward Posted August 13, 2009 Share Posted August 13, 2009 I think what happens is that if you do combine channels AND combine chops, then it will first combine the channels (in each individual input?) and after that, it does the combine chops operation. Quote Link to comment Share on other sites More sharing options...
Unik Posted August 13, 2009 Author Share Posted August 13, 2009 but it will just have a single chop/channel whatever after combining geometry and wave... there it will combine chops..right??? and then it will be just a single multiplied channel wave... one channel.. one chop... i guess i m still confused Quote Link to comment Share on other sites More sharing options...
Unik Posted August 13, 2009 Author Share Posted August 13, 2009 I don't know if I should post it here or should I use some other thread... but maybe these are related... http://rapidshare.com/files/266813382/Unik.3620.hip.html the spheres are supposed to come on the line in the form of a wave... but something's wrong..maybe in the CHOPnet.. maybe you could figure it out... Quote Link to comment Share on other sites More sharing options...
edward Posted August 14, 2009 Share Posted August 14, 2009 Do an "add", not "multiply" in the Combine CHOPs. Quote Link to comment Share on other sites More sharing options...
Unik Posted August 14, 2009 Author Share Posted August 14, 2009 hey thanks... I got the spheres on a wave..but they are not animating ... Quote Link to comment Share on other sites More sharing options...
edward Posted August 14, 2009 Share Posted August 14, 2009 Well, you have to change something so that it animates in time, like putting $T in the Phase parameter for example. Quote Link to comment Share on other sites More sharing options...
Unik Posted August 20, 2009 Author Share Posted August 20, 2009 sorry for late reply... but thanxx it is animating now....not exactly what I wanted but animating .... Quote Link to comment Share on other sites More sharing options...
Unik Posted August 20, 2009 Author Share Posted August 20, 2009 Hey Edward... thnxx its done now ... I was doing somethin very silly ... now it is fixed Quote Link to comment Share on other sites More sharing options...
