Colored Shadows
I tried to find out about it on this forum but I really didn't find any answers to it.
In other 3D packages is very easy for you to force some color on the shadows, you just have to specify it´s color and that´s it.
I know that mantra is a very powerful render engine and some things that you can do with it they are amazing but some are a little trickier like colored shadows, it doesn't have a option ready for it, besides that I am new to Houdini, so I am just beginning to understand how it works.
Does anyone knows how to change a shadow color for a specific light?
Thanks, and sorry for the bad English.
  • 2 weeks later...
Thanks for the tip.
I got a solution that works on the shader that´s applied to the object that is receiving the shadows, I just use the shadowmatte VEX SHOP inside the material to add colors to the surface using the shadow alpha, but that is a solution for some cases, what I didn't get was a solution for the entire scene.
There must be a way to replace all the materials from the scene at once without to have to set all the materials one by one, so that way I could make a shadow colored pass, but I don't know how.
Anyway I am posting my solution if you want to take a look.
Again thanks for the tip.
shadow color material.hip
