DanBode Posted August 18, 2009 Share Posted August 18, 2009 I've been going through the different primitive BSDFs to try to get a better understanding of what they each look like. The Lafortune has no documentation though. I know it can take two vectors and a float. I'm assuming that the first vector is the normal and that the float is an exponent, but I have no idea what the middle vector is. Can anyone enlighten me? I have a similar question with the Albedo function. I know when passed a BSDF it returns the portion of reflected light. Albedo can also accept two vectors and an int. I'm guessing the int is for one of the masks defined in pbr.h, but I'm not sure what the two vectors are. Thank you for any help, Dan Quote Link to comment Share on other sites More sharing options...
edward Posted August 18, 2009 Share Posted August 18, 2009 Quote I have no idea what the middle vector is Wild guess, it's the "C" vector in equation 4 of the paper: http://www.graphics....1997/LFTG97.pdf (some example values for it are given in Table 1 For some way cooler coefficients see: http://www.graphics....ts/reflectance/ (look for the "coefficient" links) Quote Link to comment Share on other sites More sharing options...
DanBode Posted August 20, 2009 Author Share Posted August 20, 2009 Oh wow. Thanks for the link! A lot of great information. While poking around in pbr.h I noticed this line: hitAlbedo = luminance(albedo(hitF, -hitI, hitNg, indirect_bounces)); So I'm guessing the extended call to albedo isn't something I'll be needing often for writing PBR shaders. thanks again! Dan Quote Link to comment Share on other sites More sharing options...
