Farsheed Ashouri Posted August 20, 2009 Share Posted August 20, 2009 (edited) Hi again. I wrote a MEL script few years ago that creates point/spot light based on a texture on a surface. Here is that mel script: sLight.mel.zip And some screenshots: How can I do this in houdini? I tried to scatter point lights on a grid but I couldn't. The main point is how can I gather RGB information of the texture or custom image on a nurbs surface and assign it to a nearest light. what I want is a fake HDRI tool. Thank you in advanced. Edited August 20, 2009 by Farsheed Ashouri Quote Link to comment Share on other sites More sharing options...
sanostol Posted August 20, 2009 Share Posted August 20, 2009 You can not scatter lights but You can instanciate lights to points and they can pick up for example color of the points with a expression Hi again. I wrote a MEL script few years ago that creates point/spot light based on a texture on a surface. Here is that mel script: sLight.mel.zip And some screenshots: How can I do this in houdini? I tried to scatter point lights on a grid but I couldn't. The main point is how can I gather RGB information of the texture or custom image on a nurbs surface and assign it to a nearest light. what I want is a fake HDRI tool. Thank you in advanced. Quote Link to comment Share on other sites More sharing options...
Ole Posted August 20, 2009 Share Posted August 20, 2009 Hi again. I wrote a MEL script few years ago that creates point/spot light based on a texture on a surface. Here is that mel script: sLight.mel.zip And some screenshots: How can I do this in houdini? I tried to scatter point lights on a grid but I couldn't. The main point is how can I gather RGB information of the texture or custom image on a nurbs surface and assign it to a nearest light. what I want is a fake HDRI tool. Thank you in advanced. I've made a light rig setup HDA a while ago. Check it out: Light Rig One Quote Link to comment Share on other sites More sharing options...
