rob Posted August 24, 2009 Share Posted August 24, 2009 (edited) I am just rendering simple 1k shadow maps with a shadow softness set to 1. You dont quite notice it at first but you get a slight moiré effect on the map. But when you use DSM merge to merge 3 maps it becomes really bad all over .Has anyone seen this before using the DSM merge. I have tried altering the bias on the 3 lights I have creating the shadowmaps to some effect but whn I use the DSM merge t really does bring into stark relief the moire pattern all over the image. Any ideas ? Edited August 24, 2009 by rob Quote Link to comment Share on other sites More sharing options...
brianburke Posted August 24, 2009 Share Posted August 24, 2009 Hi rob. I don't know what might cause this problem (if its not selfshadowing issue fixable with bias), but I think you'll find that if you exclude the ground plane from the shadow creation render you'll fix the artifact and speed up this render as well. This can be done always for objects that receive shadows but don't cast shadows. Hope this helps. Quote Link to comment Share on other sites More sharing options...
rob Posted August 24, 2009 Author Share Posted August 24, 2009 Hi Brian , yes normally in renderman / mantra a dabble with the bias clears it up. Its interesting that the DSM merge tool increases the effect and adds it to areas where it was not apparent. r Quote Link to comment Share on other sites More sharing options...
junaid Posted August 24, 2009 Share Posted August 24, 2009 just for another way out, you might want to give it a go by increasing shadow samples and see. Cheers, Junaid Hi Brian , yes normally in renderman / mantra a dabble with the bias clears it up. Its interesting that the DSM merge tool increases the effect and adds it to areas where it was not apparent. r Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted August 24, 2009 Share Posted August 24, 2009 I'd also do a test by setting DSM Compression down to 0 (default is 5). Quote Link to comment Share on other sites More sharing options...
