Align sprite to direction of travel
bandini
Thought this would be easy, but it seems like a challenge.
I am trying to align sprites so that their z axis is always aligned to the camera while the y axis is aligned to the direction of travel (with respect to the camera).
Anybody have a nice way of doing this?
  On 9/1/2009 at 6:48 PM, stevenong said:
I did a quick search with "sprite" as the keyword and found this topic.
Maybe it will give you some pointers.
Cheers!
steven
Thanks, Steven. I saw that thread while researching the problem. I came up with a similar but different solution that seems to work. I'll try to post a hip file. Maybe someone can check it out and see if they have any ideas for improvements.
-Adam
And here is the file...
There's a problem at particle birth, as the birth velocity does not match the velocity of the next frame, so you get a jump in rotation. Not sure if there is a way to get the velocity from the next frame without writing out the file to disk, since that information does not exist in the simulation yet.
AlignSprites_01.hipncFetching info...
