danilo2 Posted September 12, 2009 Share Posted September 12, 2009 Hi! I;ve got a problem with the environment variables in Houdini. In windows I've set the variable 'HOME' to 'C:\Users\Wojtek' After start of Houdini, haudini have donethere folder 'houdini10.0'. In this folderin file 'houdini.env' I added the line: 'EDITOR = D:\....exe' (of course there is full path of the program). But thisdoesn't work - Houdini doesn't seethis variable during start how to fix it? Thank you Quote Link to comment Share on other sites More sharing options...
schnelli Posted September 14, 2009 Share Posted September 14, 2009 hello danilo2! it seems the houdini.env does not work in the windows version of houdini! Set the environment variable via the windows system properties or create a batch file which starts houdini after you've set your variables. cheers Quote Link to comment Share on other sites More sharing options...
