Overload Posted September 22, 2009 Share Posted September 22, 2009 Is there a way to import and view your objects current UV set in a COP network? Similar to a UV snapshot in Maya. I see the geometry node in COPs, but that seems to import a snapshot of a geo. Thanks! A Quote Link to comment Share on other sites More sharing options...
Andy Nicholas Posted September 23, 2009 Share Posted September 23, 2009 Just copy the UV coordinates to the point positions using the Point SOP. If you've got discontinuities in the UVs then you'll first need to use the Facet SOP and select Unique Points. Quote Link to comment Share on other sites More sharing options...
Overload Posted September 23, 2009 Author Share Posted September 23, 2009 Oh wow, never even thought of that. Plug $MAPU to TX, 0 to TY, and $MAPV to TZ. Works like a charm. Your right, doesn't work without the facet. Thanks!! Quote Link to comment Share on other sites More sharing options...
Andy Nicholas Posted September 23, 2009 Share Posted September 23, 2009 Not a problem! Quote Link to comment Share on other sites More sharing options...
