sharpie Posted June 3, 2003 Share Posted June 3, 2003 Anybody have a replacement for mplay that works with Houdini? As I mentioned in the previous mplay post the thing is leaking like the boat in Perfect Storm.. Also, maybe someone would like to see if they can repro this by trying to do a test render with this tutorial scene file (attached). stage05_pinBoard.1.zipFetching info... Quote Link to comment Share on other sites More sharing options...
MG Posted June 3, 2003 Share Posted June 3, 2003 No problem for me... What OS (version), version of Houdini, videocard (latest drivers?) and kind of machine are you on? Because I generally don't have so much problems with mplay. Quote Link to comment Share on other sites More sharing options...
sharpie Posted June 3, 2003 Author Share Posted June 3, 2003 Windows XP (Sp something or other), Houdini 6 apprentice, Radeon 9000 Mobile Fire GL (driver version 6.13.10.6320 from Compaq) all running on a Compaq Evo N800w.. Can you try the scene file itself and see if it happens to you? Because I trid the scene on another machine running Houdini 6 Apprenctice and the same thing happened. I'm starting to think it will only be repro'd with that scene. Quote Link to comment Share on other sites More sharing options...
MG Posted June 3, 2003 Share Posted June 3, 2003 I've tried it! ("No problem for me..." ) It worked for me, strangely enough. And I was running it in Houdini 5.5! Quote Link to comment Share on other sites More sharing options...
sharpie Posted June 3, 2003 Author Share Posted June 3, 2003 Yeah it works in Houdini 5.5 Apprenctice for me as well, thus I think there is a problem with 6.. Its making it impossible to use.. Grrr!! I dare you to try that file with 6 and see if mplay leaks... Quote Link to comment Share on other sites More sharing options...
MG Posted June 3, 2003 Share Posted June 3, 2003 You could try reloading your HIPNC via hscript. Quote Link to comment Share on other sites More sharing options...
