Delayed loader and motion Blur
I read in the manual about the limit steps for delayed load shader motion blur, it seems it only calculates 2 geometry steps to do deform motion blur.
I have a scene that my point instances make a curve but the motion blur doesn't render right because it needs a bigger step number to calculate the motion blur.
Is there a way around it? Or I'll have to stick to this limit?
Sorry the bad English.
Edited by tomhanks
Here is my problem.
I used a particle system using point instances with delayed loader shader, the particle is using a path position to make then ride around a circle.
The motion blur is linear not curved, it doesn't follow the movement of the instances.
I tried to render with more than 2 Xform samples, doesn't render right, more samples less motion blur.
Any Ideas?
I solved part of the problem increasing the oversampling on the popnet node, if I render directly from popnet it works but the problem now is that I am not getting the same results from a cached file.
What is the correct way to save a and load a particle cache with the subframe information correctly?
