Render help on interior, darkish scene
Hi all,
I know there's a lot of resources and posts on this topic, but I'm still miffed by the noise I'm getting--in the shadows/poorly lit areas of my scene, especially--from my all my render attempts...
The first question I have, really, is this: what would you recommend using for a dark interior scene with harsh and softer lights, both (to give you an idea, it's a theater scene with footlights and a few spot lights). Would it be easiest to go PBR...?
I'm gonna put up a render in a bit, but I'd bet you guys know what ignorant thing I'm doing without even looking ^^
Thanks in advance!
Edit: Ok, I'm to the point where adding light fixes the problem... But obviously I don't want to add more light. Probably a really dumb answer to my woes, but, heheh, don't know what it is ^^
Edited by Whithers
Mantra will render out pictures in linear. So if you're not looking at it with a gamma correction tuned to your monitor, it will be wrong. The easy gamma cheat is to look at it in mplay with gamma set to 2.2.
In that past, I found that I could still tweak things without it for micropolygon renders. However, for PBR renders, it's absolutely crucial that you do it right.
ok - some points:
- ensure that mantra rop/shading/colour space is set to Gamma 2.2 - so that variance is working most in "eye" colour space. ie, smoothing out the dark bits
- use portal lights
- make use of photon maps (indirect light). reduces noise.
sidefx *really* should have a "best practice" selection of demo hip files which have all these settings tweaked to production perfection.
-paul
