Welcome to od|forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
defc0n1
String parsing in Font SOP
Hi guys
I'm relatively new to Houdini, and I've been trying to make this little digital asset. Basically what I need is to set the 'Number Of Copies' integer field of a duplicate SOP to the number of RETURN characters in the text field of a Font SOP. Is this even possible? I can do this easily in C++ but I can't get the syntax right in Houdini and I don't know how to assign it to the current field for which I'm writing the expression. I tried using the foreach() loop on the text field, but I can't figure out how to do the string comparison. Please help.
Thanks!
Share this post
Link to post
`chs("../duplicate1/ncy")`
Be careful of back-ticks, needed to evaluate the expression.
An easy way is to a right-click on channel you want to copy and paste into the text field of Font SOP.
Share this post
Link to post
I think you didn't quite understand my question. Let me clear the confusion - I want to SET the number of copies AS the number of return characters in the text field of the Font SOP. Not the other way around.
Share this post
Link to post
Indeed, i misunderstood your question.
Strange approach, on my side, i would make an integer parameter on my sop/hda/null, then put it in font sop and duplicate node.
How do you access to text field to enter your number ?
Share this post
Link to post
Yeah sorry about that. It really is a weird request. I can access the text field using ch("../font/text") but I was hoping I could do like a for loop to iterate through the characters and find the number of RETURNs in it. Basically the situation is that I need a progress bar sort of a thing (using a grid) for every line in the Font SOP. For example, if I have 4 lines, the duplicate SOP duplicates the grid 4 times.
Edited by defc0n1
typo
Share this post
Link to post
Good idea. Now why didn't I think of that? I'll check it out. Thanks fsimerey.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
