Welcome to od|forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
ejr32123
Simple Bump Map Problem
Hey,
I am using a principled shader. I have a texture pack for rocks that includes normal map and albedo. I have the albedo going through a tri planar than into base color. How can I use the same tri planar projection, but for the bump texture? The bump map is looking for a texture file (string), so I can't use my tri planar node.
Thanks
Share this post
Link to post
maybe try the op:/full/path/to/node syntax. maybe you have to add backticks `` not sure right now
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
