Welcome to od|forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
ikoon
User Interface / Maximize pane horizontally/vertically ... how do you use this function?
Please, see the attachment ... how do you use this function?
I think that it may be useful to temporarily maximize split panes, but I did not manage to make it work.
Share this post
Link to post
The easiest way to do this is to click on the arrows in the middle of the split bar:
1 person likes this
Share this post
Link to post
Hi Mark, thank you for your answer. Does that "Maximize Horizontally" do something for you? I have tried it many ways, also I have tried to set hotkey to it, but no success ... I use Alt-' a lot, but it hides everything. Those little arrows are very useful, I know, but small ... it would be so so useful to assign hotkey to them ... I was hoping to discover some good practice in the "Maximize Horizontally". If it does nothing, is it bug then?
Share this post
Link to post
There is ALT + \
This will max a splitpane, how it was split depends on if it will max horiz or vert but should reflect the same menu item available.
Be careful not to confuse with ALT+/ (forward slash) -- this will close the tab instead of maxing
i am surprised it doesn't show this shortcut in your screen grab as it should be a default
Share this post
Link to post
The Hotkeys should work on all desktops, I think this was added somewhere in Houdini 15 or 15.5?
But I don't see the KB command in the menu in the screen grab...
Did you try searching the hotkey manager and see if its is remapped? Have you hand edited the hotkeys file?
Try edit --> hot keys --> search --> String --> Maximize in split direction
and see where it is.
Maybe close Houdini, rename you hotkey file in your home directory HoudiniXX.y/HotkeyOverrides... maybe its corrupt?
It is odd that you tried to map a hot key to it previously ... it should have had the default.
Are you running this on very old or low powered hardware?
shooting in the dark a little ....
1 person likes this
Share this post
Link to post
Thank you guys very much, I reinstalled to 16.0.600 and it is working now! It wasn't working in some previous build that I had, so I thought I am doing something wrong. It is a great feature, now I see!
Thank you and excuse me please.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
