staggering a carve by primnum
I'm wondering if someone can help me out. I have a bunch of line primitives and i want use a carve sop to make them appear to grow. But I would like to stagger the effect so that prim 0 starts to animate with the carve and when its 50% prim 1 starts to animate and so on. I can't think of how to do it. I put them in a foreach loop but still not sure how to stagger the effect. help would be appreciated.
Hit "create meta import node" on "foreach begin" to allow access to the iteration attribute.
Then add the following in to the second u parameter of the carve sop:
clamp((1-$T)+(detail("../foreach_begin1_metadata1/", "iteration", 0)/2), 0, 1)
Should be good, providing your metadata node is named the same.
You can also set a vertical grid to rows and put a code like this into a wrangle:
float rad  = chf('radius');
float rot  = chf('rotation');
float time = chf('speed') * @Time;
float prim = chf('offset') * @primnum;
float surp = clamp(time - prim, 0, 1);
float side = fit01(@ptnum % 2, -1, 0.2);
float bbox = relbbox(0, @P).y * rot;
float grow = rad * side * surp;
@P.x = sin(bbox) * grow;
@P.z = cos(bbox) * grow;
helix_line_growth.hipnc
Edited by konstantin magnus
