Point Between 2 points with Normals
Hello all,
It looks simple but I just can't get it right. Imagine long fence with poles apart from each other relatively even distance. Now i need to place the Diamond mesh net between those poles.
How to add a point between 2 other points and add perfect 90degrees normals to it to copy geometry in the future. I require procedural approach doe to fence size will change.
forOdForce.hip
39 minutes ago, Nache said:
Hello,
I've try something for you. The 'attribwrangle_between_points' is placing point between itself and next point. I've tried to comment the scripts but let me know if its clear enough.
Gab.
forOdForce_02.hip
Thank you, Gabriel, it is a perfect solution. Trying to understand how it is done, awesome breakdown.
