Attribute reference not working in UV-Project-Node
Chrizzo
Hey Guys,
I'm trying to control the y-rotation of a UV-Project-Node using an attribute "y-angle", which is a float and stored on point-level.
If I type "@y-angle" in the y-rotation parameter field of the UV-Project-Node, it doesen't do anything. In the spreadsheet window it shows up with the correct value, but the parameter only gets zero as a value.
So, is it even possible to do such operation ?
Greetings,
Chrizzo
Edited by Chrizzo
Why would you set the rotation on a point-by-point basis? Just run an attribwrangle on detail, which stores one attribute for the whole geometry:
f@uv_rot_y = 24.67;
And access the attribute inside the uvtexture node´s rotation with a detail expression:
detail(0, "uv_rot_y", 0);
Edited by konstantin magnus
f@uv_rot_y = 24.67;
First of all, thank you very much for your answer. I actually tried, storing the value on detail-level, but not with the expression. This was the missing link, so thank yo again ! :)
