asnowcappedromance
Uniform Volume Shader with specular/reflection
Hey guys,
I'm trying to render points as volumes using the uniform volume shader with specularity/reflection.
I calculated a gradient attribute on my points (to emulate normals) and plugged that into my shader, but I'm having no success as all.
The same technique works if I convert my points to a volume and then use a gradient vector field, however I'd like to get it to work without having to convert my points into a volume.
Attached a screenshot of my current shader and also a hip file.
Any ideas how to get that to work?
Thanks,
Manu
uniform_volume_spec_test.hiplc
Share this post
Link to post
woooow 5 days and not a single reply, what's up Odforce?
Turns out all I had to do was to transform the point gradient attribute from world to camera space and use the PBR Metallic instead of the PBR reflect. Works really well.
Would love to know what's wrong with the PBR Reflect though, why isn't that working as expected? It does if I'm using volumes and a vector3 gradient field ...
Thanks to Andrea Sbabo for the tip to use PBR metallic!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
