jmhannu
VEX in Volume Wrangle
Hi all,
I'm trying to write some vex in a volume wrangle but I'm really struggling atm, not sure if the problem is the syntax or my inexperience with voxels.
I have a volume which I set up with random densities and then, in the next step, the density of a voxel should be affected by the surrounding voxels. I've done the first step but can't figure out how to access the "closest neighbour voxels". I guess they have some sort of index but can't figure out which voxel has which index or if I should access them by their position.
Tried to use the function volumeindex() to find index and volumesample() to take a sample from a position but both only returns 0 so I'm obviously doing something wrong. I wrote it like this:
vector pos = {2, 2, 2};
float temp = volumeindex(0, "@A", pos);
printf("%f\n", temp);
@A += temp;
It doesn't seem to matter what position I use for the vector pos, the functions always return 0 either way. So if someone knows anything about this it would be great :)
volumeRandom.hipnc
Share this post
Link to post
Never used it, but it seems that volumeindex() function already returns actual value from ix, iy, iz: volumeindex
Use "A" as volume name. To access different neighbours, increment voxel indices. Current voxel's indices stored in i@ix, i@iy, i@iz variables.
Share this post
Link to post
Thanks! But when I use volumeindex() I only get 0.00000 in return so I guess it's something wrong with how I set the "voxel vector". This might be a very basic question but what is the voxel vector?
I tried this:
float temp = volumeindex(0, "@A", set(i@ix, i@iy, i@iz));
@A += temp;
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
