primzahl Posted March 16, 2009 Share Posted March 16, 2009 (edited) Hello, I'm following the Tutorials from this site and Workshop No.8 is a nice introduction for L-Systems. In exercise No. 3 you should try get the given shape. Well, I think, I set up the rules to get close to the sample, but I couldn't find out one thing. I read the help-files and played around with some variable, but I couldn't find a Solution: As you can see the branch 'C' scales down and decreases by (in?) generation. But as in the sample, it should only scales down. How can I do that? primzahl Edited March 17, 2009 by primzahl Quote Link to comment Share on other sites More sharing options...
odforceuser42 Posted March 19, 2009 Share Posted March 19, 2009 As you can see the branch 'C' scales down and decreases by (in?) generation. But as in the sample, it should only scales down. How can I do that? FWIW, i can't duplicate the original Lsystem either, but I'm no Lsystem pro. anyway, a few "observations" : if you zoom in really tightly to the source pix, you will notice that "C" in the source does, in fact, decrease over "time" (generations). it just doesn't decrease as fast as as yours. i see the "dimensions" of the source shape to be approx 5 grid squares tall and 7 grid squares wide. whereas yours starts off fitting entirely inside one of those squares!! technically 0.25 of one square! this might not apply to any of this, but it might help. here's a doozy! they never mention that "C" needs to grow over time. in other words, why not create it with a few generations ( pre-grow it ) and then open up the comments and copy the "Lysystem string?" OK OK you can do this rather easily by hand copying and pasting the original rule, but if you want you can also go to a textport and use "opinfo." you can even drag and drop the Lsystem node rather than typing in its path. my guess is, it is a variant of this. probably a couple repeated "iterations" and then the call back to "C" again. other than that, you might try emailing the author / instructor. lastly, please keep posting your results. good luck. peace & 42 Quote Link to comment Share on other sites More sharing options...
icelab Posted April 13, 2009 Share Posted April 13, 2009 Primzahl, As odforceuser42 said, it is just a matter of size. My "C" also "decrease", not just scaling down. However, I used larger number of generation and smaller "Angle", so it looks like just scaling down. Attach my file. I also tried your rules (in lsystem5). If you really want "C" to scale down without decrease, may be you can try "nested lsystem"? I tried it in lsystem6 and lsystem7. Kam 09_ex03.hipnc Quote Link to comment Share on other sites More sharing options...
primzahl Posted April 17, 2009 Author Share Posted April 17, 2009 hallo, sorry for my late reply, I'm very busy with some papers for the university and so Houdini has to wait ... Thank you for your reply Quote Link to comment Share on other sites More sharing options...
icelab Posted April 21, 2009 Share Posted April 21, 2009 Primzahl, You are welcome. Thanks for reading my simple pdfs. Please point out any mistake I made in the pdfs if you find... Kam (icelab) Quote Link to comment Share on other sites More sharing options...
primzahl Posted June 12, 2009 Author Share Posted June 12, 2009 Hello, I fight myself through to Quote Link to comment Share on other sites More sharing options...
sam.h Posted June 13, 2009 Share Posted June 13, 2009 (edited) Hello,I fight myself through to Edited June 13, 2009 by sam.h Quote Link to comment Share on other sites More sharing options...
icelab Posted June 14, 2009 Share Posted June 14, 2009 I guess you cannot use X to replace G, as G is a special symbol and it will move forward, but X will not. That's why primzahl's final version lost all the notches. sam.h's method looks closer to the original example. BTW, the help page of Lsystem SOP mentioned that it supports context-sensitive syntax, but I have never tried: [left_context<] symbol [>right_context] [:condition]=replacement [:probability] Quote Link to comment Share on other sites More sharing options...
icelab Posted June 14, 2009 Share Posted June 14, 2009 I attached a test. Hope that help. Lsystem_test.hipnc Quote Link to comment Share on other sites More sharing options...
primzahl Posted July 3, 2009 Author Share Posted July 3, 2009 (edited) Sorry for my late answer, at the end of June there is always stress at University. Thank you both for your Inputs and for the file icelab, it help me a lot. and you're right, "G" can't easily replaced, I was in some way aware of it, but I had to much twistSOPs in my brain. I used both ideas to get the shape. Edited July 6, 2009 by primzahl Quote Link to comment Share on other sites More sharing options...
