roughsporty Posted October 9, 2009 Share Posted October 9, 2009 (edited) The funny „surprise“ scene This is the first project which I want to create. As a starting point I have created a HOT ocean with a simple shader on it, just to have something to look nice for the first step. I also have added a background image and put that through the comp. This ist the result: With sound: The next steps will be: - place a dummy (will be replaced later with a buoy on the water with natural movement - add a little movement to the camera so there is more dynamic in the scene and more realistic - replace the backdrop image with an environment and add some subtle clouds - „the surprise“ - add real foam advected from the peaks of the wave (particles / shader) - tweak the shader of the ocean - a very good lightning setup. - tweak, tweak, tweak I will place regulary my results here. After I have roughly put all things together I will put the scene file here. Would be great to discuss different approaches and maybe put some guys together to bring the rough result to a perfect one and share this with the community. Edited October 9, 2009 by roughsporty Quote Link to comment Share on other sites More sharing options...
roughsporty Posted October 10, 2009 Author Share Posted October 10, 2009 I have placed the dummy buoy on the water plane and tweaked the movement through CHOP's so it's movement looks naturally. What do you think ? Quote Link to comment Share on other sites More sharing options...
rob Posted October 10, 2009 Share Posted October 10, 2009 (edited) Hi, Great start.Are you just using displacement shaders for your ocean ?. rather than adding sound and a buoy I think you should be adding far more detail into the ocean surface. r Edited October 10, 2009 by rob Quote Link to comment Share on other sites More sharing options...
roughsporty Posted October 10, 2009 Author Share Posted October 10, 2009 (edited) Hi, Great start.Are you just using displacement shaders for your ocean ?. rather than adding sound and a buoy I think you should be adding far more detail into the ocean surface. r Hi Rob, this is not a displacement shader. There is a high density disc mesh on which the buoy is projected. You are right there is a whole lot more to do but I have no specific stages on which I am working on. The ocean is far away from being good looking, I know. What do you mean with more detail? Foam and other things? Thies Edited October 10, 2009 by roughsporty Quote Link to comment Share on other sites More sharing options...
roughsporty Posted October 11, 2009 Author Share Posted October 11, 2009 Again Rob, concerning the "detail thing I think I know what you mean :-) I have used now a displacement shader because of the detail, that doing with a mesh is not an option. Quote Link to comment Share on other sites More sharing options...
ykcosmo Posted October 11, 2009 Share Posted October 11, 2009 Looks good!!!! Quote Link to comment Share on other sites More sharing options...
roughsporty Posted October 12, 2009 Author Share Posted October 12, 2009 (edited) here is another animation so far: I think the next step is to tweak the material from the ocean (water/foam). Right now I have a fairly simple material. Just the HOT displacement shader and a very basic surface shader with a lightning model and a fresnel. Is there a a good material out there which I can use instead of recreate a working shader? Is there a way to combine 2 materials or do I have to dive in VEX? Thanks for your tips Edited October 12, 2009 by roughsporty Quote Link to comment Share on other sites More sharing options...
