pcopen VOP
MENOZ
hello!
I'd like to know how to input a sop node (like particles) into the file parameter in the pcopen VOP node, instead of write to disk a .pc file.
thanks!
Use the op: to feed things into a file pararameter.
op:/obj/myGeoObj/myParticles
It does need to be a full path, you cannot use relative paths. if you need to use a relative path you could do something like
op:`opfullpath("../myNode")`
thank you!!
Hey Mathieu,
The issue you're facing is caused by the file parameter vop. The expression you have in there for the initial value is not being expanded before being thrown into the vex code. The same expression in the "point cloud texture parameter" of the pcopen vop does seem to be expanding properly. Maybe a bug? Anyway if you delete the expression from the file parameter vop's "file default" everything should work fine.
Dan
Hey Mathieu,
Dan
I havent taken a look at the file, but one thing to note is that the "op:" syntax does NOT work when using point clouds in shaders. You have to write out your pts as a .pc/.bgeo file. .pc are more efficient so best to write out those over .bgeo's.
Edited by SpencerL
