CSN0309 Posted October 16, 2009 Share Posted October 16, 2009 Hi~ I was tried to install the hotbin_win64_H10.0.401_1.0rc8 on my houdini10.0.401_1(64bit). But now i got problem, i just copy all the files to the Houdini root path, when i launch Houdini, i got a DSO Error"(126)Couldn't load D:/Houdin~1.40/houdini/dso/SOP_Ocean.dll, This is probably because this file was intended for use with a different version of houdini" I got puzzle??why? i put the same version together. Thank you Quote Link to comment Share on other sites More sharing options...
eloop Posted October 16, 2009 Share Posted October 16, 2009 (edited) Have you put the path to the libfftw3-3.dll on your PATH environment variable ? You could, if you wanted to go this route, copy the included libfftw3-3.dll file to your D:/Houdin~1.40/bin folder alongside houdini.exe, but I wouldn't recommend that way. Instead read the installation documentation at - http://anusf.anu.edu.au/~drw900/houdini/ocean/docs/ where you will see an alternative method that involves setting a couple of environment variables. -Drew Hi~ I was tried to install the hotbin_win64_H10.0.401_1.0rc8 on my houdini10.0.401_1(64bit). But now i got problem, i just copy all the files to the Houdini root path, when i launch Houdini, i got a DSO Error"(126)Couldn't load D:/Houdin~1.40/houdini/dso/SOP_Ocean.dll, This is probably because this file was intended for use with a different version of houdini" I got puzzle??why? i put the same version together. Thank you Edited October 16, 2009 by eloop Quote Link to comment Share on other sites More sharing options...
CSN0309 Posted October 16, 2009 Author Share Posted October 16, 2009 Thank you eloop~ I already got this working! Quote Link to comment Share on other sites More sharing options...
