stamping random objects
vfxkid
hi,
i cant figure out a way to stamp random objects to a particle or points.
any help would be appreciated.
thanks in advance.
Had a look at your file and currently in your rand() expression you are using $F as your seed which means that your rand value will change every frame. I assume you want to have it change for every particle so you will want to use $ID which stores the particle id. Id is a unique number assigned to each particle when it is born.
