cookie
mabulazm
  On 10/27/2009 at 8:59 AM, Zanozza said:
First of all, there is REALLY BAD IDEA is to combine flat surfaces by cookie.
ohhh .... I do not know that, thanks a lot for your explanation, it is really helped.
  On 10/27/2009 at 3:04 PM, SWANN said:
Thats why I prefer to use extrudeSOP. Just merge those two shapes and plug them to the first input of extrude.
ok, too many ways to do the job :D
thanks for your help SWANN
  Quote
To go one step further, I prefer to lay the geometry out in this fashion, to be sure that any bevelling operations that I choose to perform later will work properly.
I did not get that, could you do a quick example to make it clear for me.
cheers
Just use a Polysplit SOP or a Divide SOP (using the bricker polygons options) to add the vertical division before the cookie operation.
