slade Posted June 10, 2003 Share Posted June 10, 2003 I was going through the HDK documentation and its state's you need the sgi c++ compiler in order to compile any DSO's and or standalone applications for houdini. Is there any options in Gcc I could turn on to compile the samples, and any subsequent dso I will eventually be writting ? and do I have to set the Hcustom environment variable ? how do I go about doin that ?. if someone could steer me in the right direction that would be greatly apreciated. Quote Link to comment Share on other sites More sharing options...
puma.snyder Posted June 10, 2003 Share Posted June 10, 2003 I have no idea about any HDK questions, but I remember Wolfwood asking something like that over at sesi forum. Maybe it helps http://www.sidefx.com/forum/viewtopic.php?...5&highlight=dso Achim Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted June 10, 2003 Share Posted June 10, 2003 As far as doing VEX DSOs the only way without the HDK is with Linux. Becareful with the newer gccs (3.x) as the name mangling has changed. I tried both gcc 2.96 and 2.95.3 and both worked. Note, this only works with VEX DSOs, all other types have to go through the HDK. jim. Quote Link to comment Share on other sites More sharing options...
