Houdini and PRman display driver
phong
Hi!
I'm using Houdini with prman on a linux os and I got problems rendering into the ip display. The output says:
R90011 {SEVERE} Can't open display image ip (System Error: Connection refused)
What did I set up wrong?
# PhotoRealistic RenderMan configuration defaults.
# See Section 2 of the PRMan User's Manual for a complete description.
/errorpath ${RMANTREE}/etc/messages
/displaytype/framebuffer ${RMANFB-x11}
/displaytype/file tiff
/displaytype/pointcloud pointcloud
/display/dso/it ${RMANTREE}/etc/d_socket.so
/display/dso/combiner ${RMANTREE}/etc/d_socket.so
/display/dso/slim ${RMANTREE}/etc/d_socket.so
/display/dso/composer ${RMANTREE}/etc/d_alias.so
/display/externserver ${RMANTREE}/etc/dspysrvr
/dspyserver ${RMANTREE}/etc/dspysrvr -hostclient rman-di
splay
# /display/dsopath /usr/yourdisplaydrivers/etc/
/display/standarddsopath ${RMANTREE}/etc/
/display/dsomapping d_%s.so
/display/socket/socketapp it
/display/socket/socketport 4001
/display/socket/itapp it
/display/socket/itport 4001
/display/socket/combinerapp combiner
/display/socket/combinerport 4002
/display/socket/slimapp none
/display/socket/slimport 4003
/standardshaderpath ${RMANTREE}/lib/shaders:${RMANTREE}/lib/shad
ers/plugins:${RATTREE}/lib/shaders
/standardtexturepath ${RMANTREE}/lib/textures
/standardvfxmasterpath ${RMANTREE}/look/masters
/standardvfxinstancepath ${RMANTREE}/look/instances
/standardproceduralpath .
/standardrifpath ${RMANTREE}/etc
/shaderpath .:@
/texturepath .:@
/proceduralpath .:@
/rifpath .:@
/prman/shadingrate 1.0
/prman/gridsize 256
/prman/texturememory 10240
/prman/textureformat tiff
/prman/texturefilter box
/prman/bucketsize 16 16
/prman/shading/debug 1
/prman/shading/objectcache 1.5
/prman/hider/mpcachedir ${TMPDIR-.}
/prman/statistics/stylesheet ${RMANTREE}/etc/html/rmStatsHtml_1.2
.xml
/prman/statistics/profilestylesheet ${RMANTREE}/etc/html/rmProfileHtml_1
.0.xml
/prman/statistics/filename stdout
/prman/statistics/xmlfilename
/display/tiff/rowsperstrip 32
/dirmap/zone/alinux NFS
/dirmap/zone/alpha NFS
/dirmap/zone/intelnt UNC
/dirmap/zone/linux NFS
/dirmap/zone/sgi_m3 NFS
/dirmap/zone/sparc NFS
# The /licensefile line below describes where applications should find
# Pixar license data. It may be given an initial value by the installer.
# The setting may be either a license file name, such as
# /licensefile ${RMANTREE}/etc/pixar.license
# or it can be a "port@host" license server specification such as
# /licensefile 9010@hostname
# You should change the value below to reflect your site's requirements.
# Note that you may alternatively leave the abstract hostname unchanged
# below and instead add this name as an alias to the real license server
# in your site's hostname database, e.g. DNS or /etc/hosts. Server port
# numbers are defined by the license and should not be changed.
# Note: the setting "/licenseserver" is recognized by newer applications,
# and it will override /licensefile if it exists here (in rendermn.ini)
# or in override files, such as ~/.rendermn.ini -- this allows you to
# maintain different settings for older applications.
/licensefile 7498@server_semester3
/licenseserver 9010@server_semester3
Thanks in advance,
Phong
Hi!
Thanks in advance,
Phong
Have you installed the Mplay display driver using proto_install ?
Thanks for your reply!
No I haven't insalled the Mplay display driver yet. I intended to use standard ip for showing the framebuffer. Is that possible?
If you plan to use default x11 display driver, then $RMANFB needs to be set to "x11". In this case "framebuffer" should open an x11 window, but I've never tried it. I always use the RenderMan Display driver that comes with Houdini as it's much better.
