Xiangbuilder Posted June 11, 2003 Share Posted June 11, 2003 1. I downloaded the arbitaryAxis.zip file from odforce. Copy ArbAxis.ds to I:\Houdini5.5.230\houdini\vex\Dialogs\Sop Copy ArbAxis.vex to I:\Houdini5.5.230\houdini\vex\Sop Copy ArbAxis.vfl to I:\Houdini5.5.230\houdini\vex\Sop Copy tri_axis.bgeo to I:\Houdini5.5.230\houdini\geo Edit VEXsop file in I:\Houdini5.5.230\houdini\vex by adding the line ArbAxis vex/Dialogs/Sop/ArbAxis.ds -inputs 2 - label "ArbAxis" -icon ArbAxis.icon In SHOP, Tab, no such SHOP, Why? 2. I downloaded jason simmons's vex hair tutorial, is JS_vexhair.tar.Z, I don't know how to use it. Winrar can't open it. Thank you. Quote Link to comment Share on other sites More sharing options...
edward Posted June 11, 2003 Share Posted June 11, 2003 Isn't the arbitrary transform axis sop replaced by the native TransformAxis sop? Quote Link to comment Share on other sites More sharing options...
Xiangbuilder Posted June 11, 2003 Author Share Posted June 11, 2003 I don't know about this. In fact, I want to ask the method compiling the .vfl file. In VOP builder, I made a Surface shader. In it, placed a skin node, wired color to Cf, Then placed a parameter. Tried to use it in SHOP. Good. But when tried to use above method to install .vex and .ds file so I can use it in SHOP in every scene. Falled What is wrong? Thank you. Quote Link to comment Share on other sites More sharing options...
Xiangbuilder Posted June 13, 2003 Author Share Posted June 13, 2003 Thank you. Find it at 2 VEX Scripting/ 4 Creating a VEX Surface Shader. The folder should be $HOME/houdini5.0/shop, and modify SHOPsurface file. Quote Link to comment Share on other sites More sharing options...
